Old 02-04-2009, 11:31 PM   #1
webfoot
'71 Dash pad removal
Attempted to remove this thing to try and find an electrical bug. Took out the 5 or so screws and expected it to have little friction clips like my chevelle, but it looks like there is more to it than that.
I'll post in the electrical forum with my other problem on the off chance its something common, if anybody wants to check it out.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-04-2009, 11:36 PM   #2
powell72
powell72's Avatar
Re: '71 Dash pad removal
There are nuts that attach it to the dash from the underside also, about six(?) if I remember. It helps to have the cluster/radio/glovebox liner out of the way, but I've gotten there just removing the glovebox liner before.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-04-2009, 11:36 PM   #3
t&tkennels
t&tkennels's Avatar
i dont think you have removed all the screws (pal nuts ) i think there is more than 5 or so, Maybe 8 cant remember . but once their all removed it comes right off, at least mine did.
t&tkennels is offline   Reply With Quote
Old 02-04-2009, 11:39 PM   #4
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: '71 Dash pad removal
It is MUCH easier to remove the dash pad if the glovebox and gauge cluster is removed, especially on A/C trucks.
1970cstblazer is online now   Reply With Quote
Old 02-04-2009, 11:42 PM   #5
webfoot
WOW you guys are fast. OK I'll go underneath it and see what I can find. This is a non-AC rig so hopefully I can get behind there. How hard is it to get the gauge cluster out, is it just the screws I can see from the seat holding it in?
-me
Old 02-05-2009, 12:00 AM   #6
ashx2
Take a deep breath and make sure there are no small children around when you start trying to get to all the nuts. In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head.
The PO of my other truck hacked the dash up to the extent that the studs would not fit into the metal dash properly anymore....and then to put it back on, they laid down two lines of silicone on the top/bottom edges of the dashpad! It took me over an hour and a half of pulling/tugging and priying to get it off!
But I finally got it. Now I'll have to put it on my daily driver when I get it all finished up.
Greg
ashx2 is offline   Reply With Quote
Old 02-05-2009, 12:05 AM   #7
webfoot
This dash pad is completely trashed anyway - is there any sort of "sacrificial" way I can get it out of there?
-me
Old 02-05-2009, 01:10 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Not really. There is a metal insert the full length of the pad and the studs are welded to it. I won't say it can't be done but you may damage something else in the process...
LockDoc
Leon
Old 02-05-2009, 09:06 PM   #9
webfoot
Boy, those little studs are WAAY up in there!! I don't see how you could even get those out without having the whole dash apart.
Then I tried to get the cluster to come forward, and couldn't figure out how to get the washer knob out of the switch.
With 3 pedals and 2 levers there really isn't a lot of room to squirm around under there, either.
-me
Old 02-05-2009, 10:13 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The light switch had a button on it.It's kinda hard to find but feel around and you will find it.Push it in and pull the knob the shaft and knob come out together.Unhook the battery since the lights will come on.The wiper knob has a small set screw.There is a plug on the dash guages and a compression style fitting on the oil pressure guage.Then the dash bezel will tip forward.Then you can usually get to the nuts on the drivers side.The glovebox has screwss you can find those.Then you can get to the pass side.The only tip I can give you is a 5/16(I think) socket 1/4 drive with wiggle joints and extensions may help.The dash pad may have "grown" in place but should sepperate with a little persuasion.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-05-2009, 10:21 PM   #11
spankrz
i took mine off my 72 about a month ago. its pretty simple. you just have to get a end wrench [i forget what size] and reach up under there blindly and feel where the nuts are. then it should come right off since you already have the screws out. if you order a repro one, it has a little bit better mounting system.
spankrz is offline   Reply With Quote
Old 02-05-2009, 10:23 PM   #12
spankrz
you are working blind, that is for sure.
when i took mine off, i had the seat out. that helped A LOT. a stock bench seat only has 8 bolts, and i took mine out myself. i am only in highschool, so you can do it.
Old 02-05-2009, 10:24 PM   #13
spankrz
LockDoc
if you are planning on trashing the pad, just rip the pad off of the metal brackets. that way you can see what youre doing a little better. ive done that before too.
Old 04-15-2009, 12:10 AM   #14
Brandoneh
I am stuck also... how do I get that damn reciever of the headlamp off? I got the knobs off the wiper and lights but the housings behing them wont move. any help? thanks.Name:  IMG00193.jpg
71 K5 In progress!
Brandoneh is offline   Reply With Quote
Old 04-15-2009, 12:16 AM   #15
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Did you remove the Bezel rings on the front off first?
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-15-2009, 12:20 AM   #16
dan42
dan42's Avatar
I would take the instrument cluster out, the radio out, the headlight switch off, and the glovebox out. Once you do that, it's still a PITA, but it's a lot easier. I just did mine about a month ago.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-15-2009, 01:47 AM   #17
tim21391
tim21391's Avatar
if your talking about the knob you pull out for your headlights.. in my 72 you pull it until it wont come out.. i dont remember which way but either if you move the lever right or left it should slide right out...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-15-2009, 05:34 AM   #18
cdowns
cdowns's Avatar
taking the dashpad off wont help in any way to fix or find an electrical problem// theres nothing near it or under it
Old 04-15-2009, 05:54 AM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I looked over this whole post, and I was saying the exact same thing the whole way though.
Old 04-15-2009, 11:35 AM   #20
Brandoneh
Smitty
Thats the one! how do I get those Bezel Rings off there? they seem to be stuck and I dont want to force them! thanks for all the info guys!
71 K5 In progress!
Old 04-15-2009, 11:36 AM   #21
Sinister
Between Trucks...
Sinister's Avatar
I put some needle nose pliers in the little holes and unscrew.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-15-2009, 11:44 AM   #22
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I spoke to mine very sternly and out it came.......
On a serious note I left the pal nuts off mine after I reinstalled for an easy life during future removal.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-15-2009, 12:15 PM   #23
Brandoneh
Appreciate all the quickness and the help fella's.
71 K5 In progress!
Old 04-02-2012, 02:20 AM   #24
KY Colonel
KY Colonel's Avatar
Subscribed
1970 K20 Custom 427/TH400/PS/PB and a dash of badass!
I was made in America, my truck was too...4 years before me.
KY Colonel is offline   Reply With Quote
Old 04-02-2012, 09:31 AM   #25
DorianB
DorianB's Avatar
Greg
I am so stealing that line about flopping around inside the cab. It describes my experiences with work in the cab so well
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2
DorianB is offline   Reply With Quote
