Restoration Virgin!
Front shock issue
Hey guys,
Been noticing a small leak under my passenger side front A-arm, come to find out the shock is leaking at the shaft where it meets the cylinder....my question is, I got these through CPP but am not very happy about having to send it back to them (under warranty) so they can check it out and re-send me another one... First, their customer service has been lacking...and second I'm not sure how long I'll be without one.... My solution is to buy a new front set (the current set are Doetsch Tech)...any board vendors/ member out there that can help me out....where is a good place to buy from that'll get'em to me quick??...should I just replace the fronts or should I replace the rears too??...should I go back with Doetsch Tech or KYB's??.... Thanks for any help.... FYI...front is lowered with 2.5" spindles only....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Re: Front shock issue
local autoparts stores have shock asorbers// walk in walk out with shocks is the way i do it
Restoration Virgin!
cdowns....thanks....another question....When I called CPP, I was told that I should use stock height shocks....not the ones for lowered trucks??...Anybody got anything on that??....If not, I might just go buy some shocks from the local auto parts store....any particular brand names better than the other??
if you dropped your truck by spindles in the front nothing changed as far as shock measurements and stock works// monroe top of the line is good same with acdelco
Old member
I droped mine with springs in the front & back.
Now this is going to sound crazy but it's working for me. I made a extension for the front shocks so I could use over the counter shocks. They have worked fine now for 3 years. In the rear I used the same front shock, they are 3" shorter and are working fine as of now. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Out of the carpool lane.
I've got a 4/5 drop and have been using stock shocks for years without a problem, even with the bed fully loaded.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
