02-05-2009, 12:10 AM | #1 |
seat belt mounting points?
Hello everyone how is it going? I live in okc and have a 1968 gmc lwb and I did a seach and maybe I didn't do it right but I couldn't fine a thread or topic on mounting a 3 point seat belt. My truck has a plastic plug on the pillar where the upper door frame and the back window meet, is it possible to mount a shoulder belt to that. Just wondering cause I need something to mount my sons car seat in safely. thank for all the great info you guys provide and with out this site I would be lost, thanks again, and have a good day!
02-05-2009, 12:13 AM | #2 |
SWB 4x4 Collector
Re: seat belt mounting points?
hey bud, that plug you are referring to, is made for a Shoulder Harness set up. If you remove that plug, you will find a threaded hole for a proper sized bolt. There was an option of a factory type shoulder harness, but they are one if not the hardest option to find for these trucks. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
02-05-2009, 11:15 AM | #3 |
Restoring it $200 at a time...
+1. Get Grade 8 hardware, 7/16-14 x 1 1/2 or so.
On the floor, I had to fab a bracket to move the retractor ('94 Olds 98)forward about 4". That will all depend on where you found your new belts.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
02-05-2009, 11:50 AM | #4 |
Between Trucks...
3 point belts are a great upgrade. Here's the ones I got: http://www.classicparts.com/47-59-an...ctinfo/28-071/
Buckle side is a wee bit short which could be a problem if you need to move the bench seat forward. I'm 6' though, so they work O.K. In retrospect, the buckle side could be extended with a piece of steel at the mount.
Beat it to fit, Paint it to match... |
02-05-2009, 03:53 PM | #5 |
thanks for all the great info. I'll be bolting in my child seat so that my son can ride with me. thanks again
