Old 02-05-2009, 02:51 AM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
1987 tachometer question
Hey guys, I normally spend most of my time on the 67-72 side of this forum, but my dad just bought a '87 K30 and I need to ask a question. Can you hook a factory 81-82 tachometer up to this and it work? or will it not because of F.I.? If it helps, the k30 has a f.i. 454, np465, and np205. Also, how hard is it took hook up if the tach is missing the white plastic connector that plugs into the back of the tachometer? Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-05-2009, 06:45 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 1987 tachometer question
You will have to move around the wires in the connector on the harness in order for it to function since the fuel gauge is on the opposite side of the connector. Just look at the backside of the 2 clusters and make a chart of each of them listing the location of each terminal.
As you are looking at the back side of the cluster assembly the terminals are numbers on what is to YOUR RIGHT FROM TOP TO BOTTOM 1-9 and on what is to YOUR LEFT BOTTOM TO TOP 10-18.
Trace the leads on the printed circuits from each light & gauge terminal and make a note as to where they go on the original cluster. then do the same for the replacement cluster. Compare them and make the necessary changes to your wiring harness. To do this you will need to re-pin it by removing the terminals from the housing and repositioning them where you need to
NOTE: I WOULD STRONGLY SUGGEST MAKING A CHART OF THE HARNESS LISTING BOTH THE WIRES USAGE AS WELL AS IT'S COLORS BEFORE EMBARKING ON THIS
As far as hooking up the tach to work, there are 3 terminals on the backside that are marked 12V, GROUND & COIL
Hook the 12V (PINK) lead into the fuse block at any "IGN" source NOT a "BAT" source This way the tach is only powered up when the key is on. Run the "GROUND lead (BLACK) over to the 6-GANG ground terminal located on the left kick panel behind the dash. The last lead should be white or even brown it needs to be fed through the firewall and you can do that by bending an old wire hanger and shoving it up and through the same grommet your speedo cable goes through. to hook it up under the hood. there is a white wire located right near the coil with that plugs into the air. This is the tach signal lead from the coil mostly used for diagnostic testing.
Below is a pic of the chart i made for my suburban before the change over and of the back side of the tach connector so you can see what I'm talking about.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-05-2009, 11:13 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Good stuff...
tvblazer78 is offline   Reply With Quote
Old 02-06-2009, 08:28 PM   #4
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
what is all that writing the wires for the instrument cluster? im planing to do my autometer guages to my factory set up but i was wondering about the wiring.
staggerd86c-10 is offline   Reply With Quote
