Old 02-05-2009, 05:43 PM   #1
enaberif
Painless Wiring Dash Harness
Looking at this guy here:
http://store.summitracing.com/partde...w=1&N=700+150+
How would you use this with the stock harness?
The plug into the current cluster is a large connector that this does not look like it would work with.
Do you have to do some splicing or something? Or does this plug somewhere into the stock wiring?
Anyone used this thing?
enaberif is offline   Reply With Quote
Old 02-05-2009, 06:58 PM   #2
redrat
gearhead
redrat's Avatar
Re: Painless Wiring Dash Harness
when i replaced all my gauges with Auto meeter gauges i used this harness. it comes with the male and female plug. you will cut the factory harness plug off and only use the wires needed for your gauges, turn signals, high beam indicator, dash lights and what ever else you need. it comes with the pins for you to crimp on your factory wires and they snap in to the main plug that comes in the kit. I would only use this kit if your changing all you gauges over to aftermarket elecrtic gauges. if your running the stock gauges go to a salvage yard and see what you can find.
hope this helps. Ryan
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 02-05-2009, 08:01 PM   #3
enaberif
Nope I'm switching all gauges to aftermarket. I just feel it looks better and will be easier.
But thanks!
