Old 02-05-2009, 07:09 PM   #1
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
"Truck wouldn't Turn OFF" Need Help
Ok guys I know this was coverd before But I can not seem to locate the thread. Heres my problem I fired up the beast today I knew I had a problem as soon as I hooked up the battery The Electric Fuel Pump & Electric Water Pump came on But I decided to try to start it anyway. After a few putt putt backfire and a louder backfire and a small fire on the Carb It was ok notthing was hurt... Then I tried again putt putt and it fired up after a year of sitting in the garage I changed the Altanator wireing and Cleaned up the Wireing under the hood. But when I turned the Key to turn it off it wouldnt turn off I pulled the Fuse to the Fuel Pump and disconnected the battery then it slowlly turned off. What did I do wrong with the wireing any Ideas of where I should start Trouble shooting?
Thanks everyone I am running a 454BBC MSD Dizzy My altanator is a 10SI Internal Regulated model. I am useing the stock wire harness undre the hood and a Painless fuese block under the hood to power my Fuel Pump, Water pump, and Electric Fans hope this info helps....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 02-05-2009, 07:28 PM   #2
GMC3
Re: "Truck wouldn't Turn OFF" Need Help
I don't know if i'm just re stating what you said but by your fuel pump turning on when hooking up the battery its not tied in to your ignition. so to correct your problem you need to wire your fuel pump to an accessory that only has power when the ignition is turned. (like how some radios turn off with the ignition and some aftermarket units are wired to run with the car off and must be turned off)
GMC3 is offline   Reply With Quote
Old 02-05-2009, 07:40 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Some wiring issues are hard to analyze especially if you did some rewiring. In this case I'd start with mechanical possibilities.
The way you describe it, it could be the float/needle valve not shutting off the fuel supply? I've had that happen before.
68gmsee is offline   Reply With Quote
Old 02-05-2009, 07:53 PM   #4
v8blaze
If your running an hei, im assuming its wired up "stock" to a start/run connection. This would mean that if the water and fuel pump were wired to constants the engine wouldnt run b/c it would be getting any spark. Id go over the added wiring to make sure it is correct. If it is i had a similar problem once with an ignition switch, BUt the key wouldnt come out of the ignition either, and the car wouldnt turn off at all.
v8blaze is offline   Reply With Quote
Old 02-05-2009, 08:19 PM   #5
cdowns
cdowns's Avatar
to both the fuel and water pumps you should b running them off relays/ the altenator wiring is probally the problem of not shutting off because its backfeeding into your ignition circuit
first thing you should do before burning your project to the ground is get a book on the proper safe way to wire a hotrod // summit jegs speedway motors all have a selection of wiring howto books
Old 02-05-2009, 09:03 PM   #6
john02fxdl
I agree with CDowns, if the alternator is the ONLY thing you changed since the last time you drove it, and it didn't do this before, your alt. is supplying voltage to the ignition system after you shut the motor down. Summit sells a relay and wiring kit solely to prevent this problem. Looks like a nice kit, comes with everything plus instructions and will set you back about $45.
john02fxdl is offline   Reply With Quote
Old 02-06-2009, 04:19 AM   #7
petey-pablo
"THE GREEN GOBLIN"
cdowns That is Exactly what I was thinking The ALTERNATOR being hooked up wrong I bought a ALTERNATOR WIRING KIT through Mad Enterprise madelectrical.com I followed the instructions carefully Maybe I over looked something as for the Fuel and water Pumps They are not wired through Relays yet but they will be I just wanted to get the truck running before I wired my relays Since I have no fenders yet.. Another thing I did do was I did change all the wireing to the ALTERNATOR I used the kit pictured as for the Fues Block the only thing I disconnected to reroute my wires was A Purple Wire And a Pink Wire from My Stock Harness other than that I left it pretty much the way it was when it was working thanks for the help guys........As for the diagram I used to wire my ALTERNATOR I will try to scan the image and show you guys how I wired it Based on instructions from Mad E..
Petey-pablo
"THE GREEN GOBLIN"
454BBC TH400,Posi
Old 02-06-2009, 08:13 AM   #8
mrein3
mrein3's Avatar
The +12v to your MSD distributor needs to be isolated from all your other accessories. It needs a seperate key on power source so you don't get feed back loops that continue to power the distributor after the key is off.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
