02-05-2009, 08:31 PM | #1 |
Cab media blasted
This was the best money spent so far. I got the complete floor welded in and now I got my cab blasted with crushed glass. I still have some work to do to the cab but I put a coat of primer on it to stop any flash rust. Here are a few pics unloading and after primer.
02-05-2009, 08:32 PM | #2 |
Re: Cab media blasted
How do you like my 1 man cab lift
02-05-2009, 08:37 PM | #3 |
Nothing to see here.....
nothing prettier than fresh sheet metal! nice.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
02-05-2009, 08:48 PM | #4 |
Formerly- 1972SuperCheyenne
My rolling chassis is finally finished, so I will be starting on my cab soon. That def. looks like the way to go. BTW, nice cab lift.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-06-2009, 12:31 AM | #5 |
Roadtrip!
Looking nice! Have it done for spring? Spring can't be more than 5 or 6 months away...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-06-2009, 01:24 AM | #6 |
Looks there all bare
70 SWB STEPSIDE 70 BLAZER 09 challenger |
02-06-2009, 08:53 AM | #7 |
Tot Roddin'
Wow... that's purdy!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-06-2009, 10:05 AM | #8 |
Active Member
Looks nice and clean and naked.
I hadn't heard of crushed glass media. Is it better than fine sand? Off topic: Are those real wool blankets? I used to have several that got eaten up by moths. Can't find 100% wool blankets these days. |
02-06-2009, 10:26 AM | #9 |
I guess the glass doesnt eat up the metal as bad as sand does. Good catch on the blankets. They are a military issue wool blanket the date on them is from the 50's. I Bought them at a garage sale for a $1 each several years ago. The people had a whole stack of them I wish I would have bought more. I mainly use them for fender covers.
02-06-2009, 12:11 PM | #10 |
BOHICA
68gmsee try stopping by your local gaurd or reserve facilities and talk to the supply SGT. They usually have thousands of those blankets laying around, if they haven't already thrown them away. They might let you have some.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
02-06-2009, 12:18 PM | #11 |
That cab is SWEET! and I want one of those one man lifts
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
02-06-2009, 04:31 PM | #12 | |
Active Member
Re. blankets: For a $1? If they're from the 50's, they should be 100% wool. I got mine when I was in the military in the 60's and they were 100% wool then. The one's I've seen at the surplus stores are all made in other countries and are real low quality polyester blend. |
02-06-2009, 05:51 PM | #13 |
who did the media blasting...most I have found are sand as well.... i want the cab lift too!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
02-06-2009, 06:10 PM | #14 |
Sweet !!! Sure beats the 4 man crew I had when I changed my cab out last fall.
68' SWB 355 CID since 1987 89' S15 4WD 4.3 08' VTX 1300R 08' Chevrolet HHR (Wife's ride) "That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage. |
02-06-2009, 07:10 PM | #15 |
x2 I guess paint does look nice too
The one man lift is cool ! Thats at least 3 peoples worth of beer you saved all for you !!!
72 C20 Longbed 05 1500 Z71 |
02-06-2009, 07:10 PM | #16 |
'71 chevy s.bed/s.side
Cab looks great!
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
02-06-2009, 07:19 PM | #17 |
Looks good!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
02-06-2009, 08:07 PM | #18 |
Resident of Here
Looks great! How much does blasting a cab cost?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
02-07-2009, 09:44 AM | #19 | ||
$200 When you look at the cost of grinder disc, wire wheels, and time its a real bargain. Every crack and crevice is spotless when you get it back. You could never get to all the corners with a wire wheel. |
02-07-2009, 09:52 AM | #20 |
sharp as a marble
I media blasted my Chevelle. It was worth the money. The guy in Orlando Fl uses plastic beads if I remember correctly. People tell me that it does not heat up the metal like sand does. The guy did the whole car, and then sprayed a metal etching primer on it so I could get it home and to the body shop with out too much surface rust. When I get started on my Blazer I will do it again. The body shop guys love not having to do the crummy task of paint removal. The other benefit IMO is no chemicals to mess up the paint work later
02-07-2009, 09:59 AM | #21 |
Got a question, you didn't have the edp blasted off...I am in the same situation with the new one piece floor and want to get my cab blasted, but not sure if the new floor should be blasted too. I have read a couple places that the edp is just put on to avoid rust when repop metal is shipped, but it should be taken down to bare metal before final paint. Believe it or not, there is a lot of rust under that edp. What does everybody else think about this?
02-07-2009, 11:07 AM | #22 |
Resident of Here
WOW! I thought it was more like $500! Man, I'm definitely going to do that!
02-07-2009, 11:53 AM | #23 | |
02-07-2009, 10:42 PM | #24 |
She looks mighty nice. I'm all set up with the blaster and crushed glass but for 200 bucks I might just have to haul it over and see Jeff myself. It is just that he is so far away. HaHa.
02-07-2009, 10:47 PM | #25 |
Are you planning to put all of the A/C back in your cab? The cab that I just picked up down at French Lake is an A/C cab and that part is pretty complete but man it looks intimidating. I hope you hook yours up so I can copy your work. It would be kind of neet to have a 39 year old rig with A/c working.
