Old 02-05-2009, 08:41 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Angry Aaaargggg!!! I Hate the Rain
Welded up a rusted out hole in the floor about a 1/2" by 1 1/2". Replaced a piece of passenger side kick panel that was rusted out. With the rain today If ound out I've got leak behind the AC unit/heater core. Water was puddling up in the corner of the floor by the kick panel with no where to go now that it's all patched up. I'm pissed, just got in from the pouring rain throwing a tarp over the cab and drilling a hole in the floor. Looks like I have an excuse to spring for a Vintage Air unit now.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-05-2009, 08:51 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Aaaargggg!!! I Hate the Rain
don't freak Sin. that's a fairly common leak. it's on the passenger side, correct. may be some dried out caulking around the heater box or the bulkhead to firewall seam. not hard to fix, but sucks when you find out during a monsoon.
and the..... L.A. and rain? what's that all about?!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-05-2009, 08:53 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
I've calmed down a little now that I'm dry. Where's the bulkhead to firewall seam?
Beat it to fit,
Old 02-05-2009, 09:19 PM   #4
tcb-1
tcb-1's Avatar
for the lack of better terms, it's a body seam under the cowl. the "caulk" the factory used sometimes get brittle from the heat of the engine. then it can allow a bit of moisture in.
your best bet is to wait until a nice day (and in LA that's 350 days of the year!), spray some water in the cowl and get under the dash with a flashlight. that's how I found my little leaker.
until then, pack a roll of paper towels and a bilge pump!!!
Doug
Old 02-05-2009, 09:37 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Cool, thanks Doug. I'm gonna have to wait for few days for this rain to clear up, then I'll have a look.
Beat it to fit,
Old 02-06-2009, 07:37 PM   #6
sleepertruck72
sleepertruck72's Avatar
Not meant to hijack the thread, but does GM still make a seam sealer (caulk ?) for the driprails, and other areas such as Sinisters problem area ? I found a leak in my driprail. My windshield seal was wet inside. It is right by the seam. I am assuming the sealer needs to be replaced. Thanks for the rain huh ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 02-06-2009, 08:28 PM   #7
PHAT TONY
PHAT TONY's Avatar
Are you sure that's the leak? GM put a little hole in each dash corner at the w/shield to drain water from said leaking w/shield and there is a drain "system" engineered into the inner rocker at the pinch weld. You can see the dash holes from looking through the w/shield at bottom corners. I had a '72 2wd that dripped from the e-brake handle when it rained, straight from the dash.
PHAT TONY is offline   Reply With Quote
Old 02-06-2009, 08:42 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Pic of the seams...
There could be an unfilled/leaking antenna hole under there too.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-06-2009, 11:07 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Thanks for the pic and the tip. Guess I'm gonna crawl out there tomorrow in the rain and see what's up with it.
Beat it to fit,
