faster, faster, faster
What gap??
What sparkplug gap do you guys recommend running in a verry warm 385? The cam isn't too big, but it's not too small either. It's a crane energizer 274 with .454 lift and something like 212 duration at .50. The compression is about 10.2-1. I have been running the standard .32? for a sbc, but was wondering if it needed more for the extra ci and compression. Any ideas?
I'm going to Law School, wanna debate? It's good practice. |
Fabricate till you "puke"
Im running a recurved HEI with hot coil & module. The autolite platinums are gapped @ .042(9.8 to 1 383), the specs are in my signature.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
OK. I forgot to mention that I also hava a MSD 6AL box. I thought that a wider gap would be a little better, but I was a little unsure. My hei is also recurved do delay the advance a bit. So a little larger gap is the way to go?
With the MSD box, I would go a little wider.....i cant say for sure how much, but would think about .050, & just play with the gap till she runs the best. Im runnin Accel pcs, & seem to run fine @ .042- .045.......the hotter the spark, the more you can open the gap. Good luck.....crazy AL
Thats the Hillbilly way
I would try .045 ,thats what I run on a hei .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
yea i agree with crazy longhorn try somethin around .050. .032 is way too small of a gap for an hei dizzy. u should actaulyl have a noticeable increase in power just from changing the gap but u might wanna get spark plugs that already have at least a .045 gap to start with
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Thanks for the info guys. Thats what I was wanting to hear. I thought the gap was too small, but I just wanted make sure before I regapped them.
Running a 350 (360 now) with an HEI.
Had R44-TS plugs gapped at .035. Swapped them out for R45-TS at .045. Is this a good thing? The rear plug on the passenger side was gunked up big time. Have been told it's from the additives in the gas. Is this correct? Thanks |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
r45ts I'm running are gapped at .045 and I just run the regular hei... I dont have all those other goodies...yet
