Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-06-2009, 10:00 AM   #1
ole6320
to dyno or not to dyno
I recently acquried a 406 sbc that runs on e85 and just had a cabr built for it, instead of paying 300+ dollars to throw it on the dyno, do you guys think I should try and tune it myself or pay the guy that built the carb do it?! Does 80 an hour sound reasonable on the dyno with tuning?
1986 Chevy C-10 2WD Long Box
406 SBC 12.5/1 compression
E-85 monster!
ole6320 is offline   Reply With Quote
Old 02-06-2009, 10:34 AM   #2
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: to dyno or not to dyno
IMO you can never go wrong with having a motor dynoed, there a just so many more aspects that you can see (like how much fuel is being used, the A/F of each cylinder). Plus you can actually know how much horsepower you have which is always a plus in my book.
ProStreet68SB is offline   Reply With Quote
Old 02-06-2009, 03:09 PM   #3
Alex1
Alex1's Avatar
PLUS the cam (if not roller) will be properlly broken in.
Alex1 is offline   Reply With Quote
Old 02-07-2009, 10:12 AM   #4
Malibu 496
Junior Member
Malibu 496's Avatar
I would have it dynoed then it will be tuned and if there are any problems you can fix them before you install it. Where are you looking at dyno for $80/hr?
I had mine done here http://randrperformance.com/ and I thought it was about $250 for a 4 hour session.
1970 blazer, street/strip project
1963 ford fairlane sports coupe 50,000 original miles
Malibu 496 is offline   Reply With Quote
Old 02-07-2009, 12:39 PM   #5
djracer
djracer's Avatar
I've never had one done but it would be cool. I dyno mine on the quarter mile.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-07-2009, 01:46 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
I am a believer in the chassis dyno . I found around 40 HP in carb tuning . I also drag strip dyno .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-07-2009, 02:34 PM   #7
whatnow123
whatnow123's Avatar
I use the butt dyno myself... I floor it and see what my butt does.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 02-07-2009, 03:19 PM   #8
djracer
djracer's Avatar
I like a chassis dyno too. Be for warned they will hurt your feelings!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-08-2009, 07:42 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Ya , First pull he said 260 Hp But just get a baseline and work from there . I had alot of little things to fix and then went to carb and timing .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-09-2009, 12:34 AM   #10
Super73
Super73's Avatar
I'm a dyno whore. I could spend all day perfecting a tune. I think I have made over 75 pulls with my truck..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-09-2009, 08:38 AM   #11
djracer
djracer's Avatar
Chassis dyno?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-09-2009, 01:54 PM   #12
Super73
Super73's Avatar
Yes.. Probably 3-4 different combo's.. What is interesting though, with no changes to the combo, the tune can definately change from day to day with different density altitude..
