USA love it OR leave it!
nerf bars?
Any way to put nerf bars on a 82? If any one can help I would appreciate it. Pics?
Thanks. |
yes... they should make some that fit... thought i dont like them.. unlike newer trucks (maybe its just 4x4s) where the frame is visible below the body, our years arent! so you would have to make/mount a drop bracket.. so the nerfs really wouldnt be mounted directly to the frame.... ATLEAST THIS IS WHAT I HAVE OBSERVED....I COULD BE WRONG I HAVE NEVER MOUNTED THEM.. YOU MIGTH STROLL OVER TO THE 4X4 FORUM OR EVEN COLORADOK5.COM...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
I've seen it done before. They were nerf bars for an extended cab. The only modification was fabbing a bracket since the gas tank is in the way. It looked good and someday I would like to put some on my truck.
ChevyChic 86 Chevy K-10 If I can't be a good example, then I'll just have to be a horrible warning. "You're braver than you believe, and stronger than you seem, and smarter than you think" - Christopher Robin |
Workaholic
http://www.smittybiltinc.com/
They will have what you need--you can use their online catalog and find the exact ones for your application.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
