Old 12-10-2002, 08:46 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Power Steering Hose Ends
I bought a set of braided hoses and end for the Zoops pump and reservoir. The swivel nuts are quite a bit smaller than the hose itself. Is there an easy way to get them over the hose? I don't want to mess up the braiding. Attached is a diagram I found on the web.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 12-10-2002, 09:41 PM   #2
guitarman
Do it well or don't do it
guitarman's Avatar
The diagram you posted pretty much sums it up. It's a PITA and expect to get stuck with the braiding wire at least once. If you have to cut the hose the best way I know of is use a sharp chisel and smack the chisel with a hammer over the anvil part of a vise. It cuts it clean. I learned that trick watching some guy in John Forces pit crew. He was putting a new end or fitting on a hose between rounds.
Try to be the person your dog thinks you are.
Excellent paint and body site:
http://www.autobody101.com/
Visit my Web Site
http://home.attbi.com/~agfosteriii
guitarman is offline   Reply With Quote
