Old 02-06-2009, 10:34 PM   #1
custom63
custom63's Avatar
A Arm bushings
I am in the middle of my frontend suspension tear down and I want to replace my old worn out A arm bushings on my doner 1980 setup but I am havin the toughest time gettin the upper and lower shaft nuts to come loose. Anybody have any thoughts?
custom63 is offline   Reply With Quote
Old 02-07-2009, 03:17 PM   #2
LONGHAIR
Re: A Arm bushings
FIRE....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-07-2009, 06:41 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: A Arm bushings
Originally Posted by LONGHAIR View Post
FIRE....
yep.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-08-2009, 12:53 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: A Arm bushings
And a big breaker bar. Make sure the threads are clean on the shafts or they will bind...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-08-2009, 06:53 AM   #5
meansting04
meansting04's Avatar
Re: A Arm bushings
If you are talking about the actual shafts that hold them to the vehicle i just did mine on my 70 and i clamped the control arms in a vise and used a big breaker bar and a buddy. They are set to about 90 ftlbs. on the lowers so you figure 20-30 plus years and they get pretty stuck.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
