Old 02-06-2009, 10:46 PM   #1
Lionc68c10
Lionc68c10's Avatar
Question about squeaking noise
When I push on the gas pedal and reeve the engine at its loudest point I hear a squeaking noise. Then also happens when I gun it, I have a three speed automatic, right before the gear kicks in two second the squeaking starts then stop once I am second, but then once I start to drive up above 55 the squeaking comes back. If I do not gun it or reeve the engine there is no squeaking noise. Any Suggestion? Also, I thought it might be the belts, but shouldn’t the squeak as soon as I start the truck?
Lionc68c10 is offline   Reply With Quote
Old 02-06-2009, 11:46 PM   #2
jrdv
jrdv's Avatar
Re: Question about squeaking noise
It is probably your belts. I had the same problem and found out my fan belt was too wide for the alternator pulley ( It didn't fit down inside the pulley groove). I bought a different belt and that solved my problem.
Belts will also squeal when they get dry rotted and brittle.
john
jrdv is offline   Reply With Quote
Old 02-07-2009, 12:08 AM   #3
theyammieguy
accepting donations
theyammieguy's Avatar
Make sure the bolt that holds the alternator on the head is not broke.
When I hear mine squel I know the bolt is broke.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-07-2009, 02:43 PM   #4
Lionc68c10
Lionc68c10's Avatar
You guys were right as always I replaced my belts and now my truck sounds like the beast it is
Old 02-07-2009, 07:00 PM   #5
70Custom10Nut
70Custom10Nut's Avatar
Doyou have power steering? If you do, check the hoses. I had the most irritating squeak that I couldn't find for the longest time. Checked all the usual suspects with no luck. It turned out to be the metal collar of the PS hose rubbing on the frame. goodluck Cnut
70Custom10Nut is offline   Reply With Quote
