Closed Thread
Old 02-07-2009, 01:19 AM   #1
jmedero
jmedero's Avatar
step cont arms or drop spindles....
Ok lets open this up for discussion. Budget minded as we all are.... what is the better option? Welding in a step on the factory control arms or drop spindles? Truck is getting a 3' z or a raised and noctched x member. 22's. It will be bagged. Pros and cons of each...... ok go.
Nate I hope to get your expt opinion on this as well.
jmedero is offline
Old 02-07-2009, 01:50 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: step cont arms or drop spindles....
Well drop spindles wont mess with your geometry at all, just lower the stance
raising the BJs will move your upper control arm up & start affecting the geometry some, not that that is a major problem, but it can be if you start moving it enough
So I vote drop spindles
Just not low enough...
Sinister
Killer
Spray-Bomb is offline
Old 02-07-2009, 02:23 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
As Spray Bomb mentioned, one of the drawbacks to stepping the control arms is the effect it has on the suspension geometry.
I vote drop spindles too. I think you should be able to find some for a good deal these days.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline
Old 02-07-2009, 02:28 AM   #4
Twisted Minis
Twisted Minis's Avatar
Stepping your control arms doesn't actually affect the suspension geometry. Your geometry still see's all the pivots on the frame and spindle the same as they where before. I'm being technical though.
What it does do, is increase your camber gain, because you are moving your control arms up. While you still retain the same ride you had before, you are pushing the suspension farther up in it's travel.
That said, Spindles are always my first choice. Always. Especially if you want to lay on big wheels.
If you can find it cheaper, I can fix it!
Twisted Minis is offline
Old 02-07-2009, 08:21 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Spindles, for those that can't TIG. Which would be me..
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 02-07-2009, 09:52 PM   #6
Shane
Shane's Avatar
<-- me too ... at least not like Twisted ... dude's an artist.
Shane is offline
Old 02-07-2009, 10:05 PM   #7
jmedero
jmedero's Avatar
Nice. Thanks for all the input. Always good to pick ones mind before you start cutting into your truck.
jmedero is offline
Old 02-07-2009, 11:16 PM   #8
XXL
Señor Member
XXL's Avatar
I disagree.
1) most people I've seen step control arms only do the bottoms. In this case, you're actually misaligning the pivot angles of the upper and lower arms. Definitely a geometry issue. 2) for those who step both the top and the bottom, while the 2 arms aren't misaligned with one another, they are on a different arc path than stock. Also a geometry issue. Will it work? Sure.
XXL is offline
Old 02-08-2009, 12:27 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
Stepping the control arms DOES EFFECT your suspension geometry and kinematics... technically speaking.
At least we both agree on the solution!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2009, 02:06 AM   #10
Twisted Minis
The way I see it, moving the pivot up on the control arm, is similar to just cutting the coil. The angle of the arm, in relation to the pivots (bushings and ball joints) still see the same imaginary line. The only difference when stepping the control arm is that part of the arm doesn't move, but your suspension will still see the same pivots, only in a different position. The same as cutting your coils, only with a different ride quality.
I will draw a diagram to explain this if I need to.
Old 02-08-2009, 02:23 AM   #11
PBFAB.COM
PBFAB.COM's Avatar
I think you were confusing my wording... The effects come from the changes in the bump (2") not the changes in the theoretical pivot points (as you have clearly stated two times). I never said it "changed" the factory geometry, just has negative "effects" on it and its kinematics due to the tighter arcs created by the compressed suspension. We have the same opinion, because it's fact... but to say it has no "effect" is false.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2009, 02:29 AM   #12
Twisted Minis
Okay I get what you are saying now. I agree it does effect your suspension. What XXL was saying about creating a geometry issue is more what caught my attention. But I believe that could be the same misreading again. But yes, as you said, the further the suspension is compressed, the further it is pushing it's intended design limits. So anything you can do to reduce that is good.
Old 02-08-2009, 02:30 AM   #13
Twisted Minis
I think I am using the word geometry too critically, and also not thinking about the change in control arm angle effectively changing your front IC.
Old 02-08-2009, 10:14 AM   #14
jmedero
jmedero's Avatar
See this is what I wanted. To hear the experts explain it. I am no expert in susp. That being said I have owned a bagged truck and have dropped many of my own vehicles.
Now I know the answer to this next one before I ask it. The answer is to get a Dropmember. But here we go.
3 inch z'ed or raise the xmember? I have seen many done but still am looking for opinions on what is the best and most effective solution. I like the raised xmember into the frame b/c you can then center wheel.
What do you think?
jmedero is offline
Old 02-08-2009, 11:55 AM   #15
vin63
It's Better With Nitro
vin63's Avatar
One of the more important issues to consider when you step the control arm to move up the ball joint location is that unless you compensate for or modify the steering arm, you do, in fact, change the geometry and introduce the potential for severe bump steer. With the ball joint at a higher location and the steering arm unchanged and at the higher location, the angle of the tie-rods increase, changing the angle or geometry.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 02-08-2009, 12:05 PM   #16
SCOTI
SCOTI's Avatar
That's assuming the location of the tie-rod to steering arm & subsequent geometry was ideal to begin with (having zero bumpsteer). GM has offered more than one vehicle w/less than optimal suspension design (G-body Malibu is one such veihicle that came from the OE w/bumpsteer issues).
So it's possible it can alter that relationship; making something less than ideal to begin with even worse.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 02-08-2009, 01:13 PM   #17
Twisted Minis
See this is where I disagree. Like I said before, the pivots all still see the same line. You step the arm, it's the same as cutting a few coils.
Old 02-08-2009, 02:16 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
The Z makes more sense to me for a few reasons: 1) You can get an easy 3" from the Z, more than 1.25" crossmember section and you run into major steering issues. 2) You can still center the wheels with a Z, just make your frame cuts at an angle.
Downside: lots of work, raised engine leading to a ton of problems, blah, blah, blah...
That's what I would do, hell, that's what I did. Twice.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now
Old 02-09-2009, 10:19 AM   #19
vin63
vin63's Avatar
Most vehicles have some sort of bump steer condition because the steering arc is generally different than the control arm(s) arc - traveling in different radi (usually the control arms are shorter than the steering link). I'm just noting that if you increase the angle difference of the steering arm in relation to the lower control arm, a severe bump steer condition can be introduced and be potentially dangerous.
It's very different than cutting coils - when you cut a coil, the tie end rod still travels in the same original plane in relation to the lower control arm. However, once you change the angle plane of the steering arm in relation to the angle plane of the lower control arm, you start to introduce the potential for severe bump steer. If the steering knuckle or arm on the spindle moves up by a ball joint spacer or stepped lower control arm without an equal spacer for the tie rod attachment, the angle of the tie rod changes in relation to the lower control arm angle. That's why a dropped spindle generally has a kick in steering arm (to keep the tie rod in the same location as the stock spindle) - that's to help maintain the original steering geometry. I'm just providing my 20+ years of experience in building hot rods and race cars. You are welcome to do what you want, I'm just trying to prevent you from having an ill handling vehicle, which are no fun and can be dangerous.
vin63 is offline
Old 02-09-2009, 10:25 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
....I'm just trying to prevent you from having an ill handling vehicle, which are no fun and can be dangerous.
And we appreciate your input.
Articles-
"Refining Sierra"
N2TRUX is offline
Old 02-09-2009, 10:53 AM   #21
SCOTI
SCOTI's Avatar
Actually, I thought the spindle 'spud' being raised in relation to the steering arm is what makes drop spindles desireable vs. raising the BJ locations (stepping the a-arm). The steering remains as the OE intended.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 02-09-2009, 11:44 AM   #22
vin63
vin63's Avatar
The steering arm is generally cast at about the same vertical location as the spindle pin as a structural component to the casting in addressing the shear load required to rotate the spindle/tire/wheel assembly under steering conditions. In a dropped spindle the spindle pin is located higher, so the arm is attached higher in the casting and then drops down - for example, 2.5 inches in a 2.5-inch dropped spindle. Take a look at a stock spindle casting next to a dropped spindle casting...you'll see what I'm talking about.
vin63 is offline
Old 02-09-2009, 12:54 PM   #23
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I had a 62 Olds with stepped arms and it handled great! But if they would have made a dropped spindle for the car....i would have bought them!!
crawdadfox is offline
Old 02-09-2009, 01:12 PM   #24
SCOTI
SCOTI's Avatar
I'll do that. Good info to know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 02-09-2009, 06:53 PM   #25
jmedero
jmedero's Avatar
See all that I am learning. Thats is why I like good questions. For my application is seems that the $300 spend would be better to get the spindles. After all from what I hear I will have my own issues with steering and other stuff with the Z.
jmedero is offline
Closed Thread
