02-07-2009, 03:29 AM | #1 |
Member of the longbed union.
Tilt Steering!
Can someone tell me what steering collums will bolt up with little or no mods. I'm looking for tilt steering and dont have a clue as to what years will work. Or if theres another thread with this info. my truck is a 64. Thanks for the help!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
02-07-2009, 12:10 PM | #2 |
TexasBowhunter
Re: Tilt Steering!
I used one from a 77 Blazer. I also used the bracket from under the dash that has the brake pedal on it. It makes lining up the holes and linkage for power brakes easy!
Build in progress for son's first truck. |
02-07-2009, 12:20 PM | #3 |
Re: Tilt Steering!
73 to 80 van column. Not much mods need to be done. Maybe weld some nuts on column to bolt up to the bracket. You can get a collapsable lower column also. The column in the pics are from a 79 and it is a tilt. I have changed it out because the shifter was sloppy and now there is one from a 76 van camper in it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-07-2009, 01:40 PM | #4 |
Re: Tilt Steering!
Not trying to jump the thread but which year columns are the ones that will bolt over with light mods, has tilt and DOES NOT have a key in the column. I want to keep my key in the factory place of the dash.
02-07-2009, 01:53 PM | #5 |
Re: Tilt Steering!
tilt steering for our trucks, aftermarket or later model swap ins?
http://67-72chevytrucks.com/vboard/s...d.php?t=291299 |
02-07-2009, 02:08 PM | #6 |
Re: Tilt Steering!
Awesome link Woogeroo! That helps alot. Now I just have to find one.
02-07-2009, 02:44 PM | #7 |
Re: Tilt Steering!
Thanks for yalls help, Anyone have some around East or Cen Texas tha I could get, tilt, floor shift
02-07-2009, 10:16 PM | #8 |
Re: Tilt Steering!
The Van column. From 73 to 80.
02-07-2009, 10:51 PM | #9 | |
Re: Tilt Steering!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
02-07-2009, 11:05 PM | #10 |
Daring to be Different
Re: Tilt Steering!
I just bought a Camaro Tilt column. I'll be installing it in my 65. Look for it in my build thread. I chose the Camaro Column because I want a floor shifter.
http://67-72chevytrucks.com/vboard/s...d.php?t=327644
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 02-07-2009 at 11:07 PM. |
02-08-2009, 01:07 AM | #11 |
Re: Tilt Steering!
where did you get your conversion knuckle? does your column have splines?
CHEVY ONLY Last edited by joe231; 02-08-2009 at 11:14 AM. |
02-08-2009, 02:27 AM | #12 |
60-66 Nut
Re: Tilt Steering!
Another application for tilt columns that will work is in class A and B motor homes (Winnebago's) I've got one that came out of a '89 motor home and it is just like a regular van column.
02-08-2009, 10:57 AM | #13 |
Re: Tilt Steering!
I pretty much install the column with the bracket under it, line up the column and mark where the bolt holes are on the column and just tack on a couple of nuts to the column and put it back in to make sure they are lined up right. After that you can pull the column back out and put a few more tach welds on the bolts so the stay put.
02-08-2009, 10:59 AM | #14 |
Re: Tilt Steering!
You can get them from Summit or a local speed shop. It is a combo 36 spline with a DD fitting on the other side. The picture shown without the front sheetmetal on, has a 73 to 87 lower truck shaft on it.
02-08-2009, 11:16 AM | #15 |
Re: Tilt Steering!
cool, thanks!!
do you know the diameter of the splined side? I see 5/8", 3/4", and 13/16" i'm guessing both the splined and the DD are 3/4"?
CHEVY ONLY Last edited by joe231; 02-08-2009 at 11:26 AM. |
02-08-2009, 05:33 PM | #16 |
Re: Tilt Steering!
They are probably 3/4.
02-08-2009, 09:36 PM | #17 |
Re: Tilt Steering!
CHEVY ONLY |
