Old 12-10-2002, 10:23 PM   #1
Prerunner1982
Prerunner1982's Avatar
Fill TWO tanks from ONE neck...
i know there has been some questions about this.. today i had the chance to look at my buddies truck with his bed off (82 silverado)... he cut a hole in each tank, used aircraft wing sealer, (could also be welded) to mount a piece of tube (1.5") on each tank then ran a steel braided hose from tank to tank.. he can fill up from both tanks, runs off one gauge, and use one pump, though he choises to use two...
side note.. he plans on making a skid plate to mount from one side to the other where the hose is.. as the hose hangs BELOW the drive shaft..
OR (as i also discovered)
There is enough room between the frame and the bed to put a Y tube in each filler neck and run a hose from one side to the other.. you could fill from one side.. but would have to use switch and run sending unit/pump for each side..
I think i will go with choice two. its a tad easier and get the hose up higher.. as i like to play off road when i get a chance..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-11-2002, 03:15 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I agree that choice 2 is much better idea. But for as often as I use both tanks I'll stick with the filling up both at the same time using 2 diiferent pumps
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-11-2002, 03:33 AM   #3
Prerunner1982
i like the fact that the fuel can freely go tank to tank in choice 1. but dont like the hose location.. after i clean out the passenger side tank (filler neck is tied up because i dont have a filler door yet, didnt notice the cap had come off..went mudding... lord only knows now much muck is in there) i am going to to do choice 2, i usually dont use 2 tanks.. but that has to do with the fact i dont like to have to set the pump down and turn truck around. someone always thinks i am leaving and pulls up to the pump..would be even better if the Y on the driver side was a switch.. to select the tank..
besides.. my "new" bed doesnt have a fuel door, this would fix the problem...
Old 12-11-2002, 11:27 AM   #4
PHOENIX
Is there enough room to weld pipe from tank to tank?That would allow you to fill up both and do the same as the hose. There must not be enough room or Im sure your friend would have done it that way. I like the idea of filling both tanks from one side though.
EDIT:
Welding a pipe may not be a good way, because of flexing and what not.
But the tanks should be connected at the bottoms as stated in the next post.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-11-2002, 01:06 PM   #5
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Cool
That's odd...I've never had problems filling the dual tanks on my '86. I just pulled up, and stuck the nozzle in the driver's side, and then went around to the passenger side, and stuck that nozzle in.
Oh, that's right! I have a diesel! It was really nice to be able to pull into a truck stop and use the diesel pumps with nozzles on both sides!
On my '81, I have a spare tank in the bed, so both tanks fill from the driver's side.
I really don't think the filler tube across the top will work. The gasoline will want to take the path of least resistance, and so it will fill up the closest tank first, and then it will have to run almost vertically to try and fill the other tank. Since the first tank will be full, it will keep clicking the nozzle off long before you ever get much fuel in the second tank.
Liquids like to flow down, not across.
However, the bottom feed would work, because the fuel filling up in the first tank would run across to the other and equalize.
Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
Old 12-11-2002, 03:07 PM   #6
Prerunner1982
casey... good point.. but i will see what i can do..i think this would be the best way since i dont have a fuel door for the other side...
Old 12-12-2002, 12:04 AM   #7
MJN
MJN's Avatar
My dad had a '71 GMC that had the add on dealer tanks in the box and they filled from one filler neck. As the first one got full it ran across the frame and into the other tank. I've never seen another like it and neither has my dad. At least it's a possibility.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 12-12-2002, 12:59 AM   #8
Hooter
My other Love
Hooter's Avatar
i like having two tanks. When I pulll into a gas station on the wrong side, I don't feel like an idiot
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-12-2002, 02:06 PM   #9
PHOENIX
Hooter that is the good thing about the 2 tanks. You can pull into either side. But since my switch valve isnt working right now, I always use the driver side.
Old 12-12-2002, 07:34 PM   #10
79BIG10
79BIG10's Avatar
Sounds like a problem for the fuel valve king to figure out for you
