Old 02-07-2009, 08:19 AM   #1
dhughins
dhughins's Avatar
how well would a elcamino rearend work?
what is the bolt pattern? how easy would it "bolt in"? what gears were in them? anybody tried to put one in a 64 yet?i have a 79 c10 front that is 5 lug and want a 5 lug rear. if the bolt pattern is different would it be worth it?
dhughins is offline   Reply With Quote
Old 02-07-2009, 08:45 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: how well would a elcamino rearend work?
bolt pattern is "small" gm.
your c10 front is "big" gm.
they are different.
gears could be anything depending on the year and transmision, however most autos were 2:73
Old 02-07-2009, 10:17 AM   #3
dhughins
dhughins's Avatar
thanks
Old 02-08-2009, 01:12 AM   #4
Captainfab
60-66 Nut
A friend of mine used one from a '69 El Camino in his '64. Seems like it was just a little bit narrower. Of course the trailing arm mounts had to be welded on and as Jon said they are 5 x 4.75 bolt pattern.
