Old 02-07-2009, 01:55 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Hood hinges - how to tell if they are GM or repop
I picked up a set of hood hinges today - I was told they are NOS - the have the part number painted onto the side - 3911705LH 3911706RH
The have a hang tag on the but the label is so faded you can not read it - it did strike me as a part tag for GM
Any way I can tell for sure which these are?
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-07-2009, 09:53 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Hood hinges - how to tell if they are GM or repop
I don't know how to tell. If a person had an original pair you should be able to compare them... I've never seen a pair of aftermarket ones.
LockDoc
Leon
Old 02-07-2009, 10:21 PM   #3
WillW23
Well I have rebuilt many sets or original Truck hood hinges over the last 5 years, and I have seen 2 different kinds of rivet facings. Most have the X or the plus sign, pressed into the top of the rivet, and flared, and the other has the X pressed on the outside edges of the rivet, and flared. I have never seen any with the cast numbers on the hinges, like Chevelle SS hinges were done. As long as they are tight and straight, I would use them, since so many core hinges i get are worn slam out.
WillW23 is offline   Reply With Quote
