Old 02-07-2009, 02:27 PM   #1
rddiaz
rddiaz's Avatar
Front won't lay???
Hey guys,
I bought and installed a dropmember. I used the factory control arms with slam bags 2600 and 2 1/2 inch summit drop spindles (ground force). I went to lay it out and it won't lay all the way. I thought it would lay with the factory CA. It lays on the gas tank in the back and even when I lift the back all the way and the front all the way down- it still won't lay flat. about 1-1/2" from it . Hopefully these pictures will show what I'm talking about. I know I need to buy ART arms, or sumtin similar but can I get away with just buying the bottoms or the tops (either or)? These tires are 29" tall, and I'm going with 30" tires w/ 22's. Maybe I should start a build thread?
first off hre is my truck now!!!
sorry they are out of order!!!
I know KP has some lay arms now but will SD arms fit the DROPMEMBER? any info would great!!! Oh and thanks to N2TRUX for gettin to my bumper question.
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 02-07-2009, 06:40 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Front won't lay???
Looks pretty damn close to me. Is the transmission cross member holding it up? If not, looks like you are going to either modify the control arms you have so the bag sits down inside them more, or just buy new tubular ones. This is a common problem for people running the lower plates. If you flat out don't have the cash right now, modifying them will work fine until you can upgrade.
I'm assuming you are getting a fuel cell to mount in the bed.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 02-07-2009, 06:44 PM   #3
royo
royo's Avatar
well i guess you got something holding you up? heres mine with stock spindals and 28in tires
nickle and dime
royo is offline   Reply With Quote
Old 02-07-2009, 07:00 PM   #4
rddiaz
rddiaz's Avatar
hey smashingchuck, modify in what way? you mean take off the bottom plates and put in cups? if so, how tall do they need to be in order to lay CA like royo!!!!!!YES I'm jelous.........Anyways I plan on sectioning the tanks eventually but for now they are going to have to stay there. Is there any way to raise the tanks for some clearance?..........
Old 02-07-2009, 07:13 PM   #5
hotrodhomi
hotrodhomi's Avatar
I would install a blazer tank in the rear or get a fuel cell made.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-07-2009, 07:18 PM   #6
smashingchuck
I can't find any pics but some people cut the middle of the control arm out, weld a large diameter (8"?) 1/4 wall piece of pipe in, and drop the bag location mounting point down by about 2" or so.
78 Build Thread
4Runner Build
Old 02-07-2009, 08:15 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by hotrodhomi View Post
I would install a blazer tank in the rear ......
I vote for Blazer tank. Fuel cells just don't look right in a street truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-07-2009, 08:31 PM   #8
Sweet 85 C10
OG
Sweet 85 C10's Avatar
Something has to be holding you up there! Looks good though!
Sweet 85 C10 is offline   Reply With Quote
Old 02-07-2009, 09:18 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
The factory gas tanks sit just below the frame, and also the driver's side lower frame rail has a "kink" in it where the catalytic converter used to be. Also, with the factory lowers, bag plate,and SlamBag it will keep you just off the ground. Make sure it's not the tanks and frame on the driver's side first. If those aren't the issue, swap the Slambag for a Firestone it will get you that extra inch.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-07-2009, 09:58 PM   #10
rddiaz
rddiaz's Avatar
hey thanks guys, I wish I could get that blazer tank but that area is now home to an 8 gallon air tank and valves I will have to get a pic of it as soon as I can find it. Oh yeah what about that "kink", how would you go about straightening that out? Hey nate what about those CA in my earlier question.......
Old 02-07-2009, 10:51 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by rddiaz View Post
....Oh yeah what about that "kink", how would you go about straightening that out?.....
Rosebud tip and a big crescent wrench should do it.
Articles-
"Refining Sierra"
Old 02-07-2009, 11:29 PM   #12
rddiaz
rddiaz's Avatar
I'm gonna have to try that n2trux thanks again.here is one picture of the tank, I'll take a better one 2morrow with everything welded up and ready to go
I know someone here did what smashingchuck was talking about with the control arms, anybody remember who?
Old 02-08-2009, 12:08 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
There are a few ways to accomplish what you're looking to do.
1. Purchase 3" drop spindles and go with a tubular lower arm from ART, KP... or wait a little bit longer for mine to come out.
2. Modify the factory lower arms and set the bag approx. .75" lower in the arm.
3. I am pretty sure a firestone bag will do the trick... it compresses more than a Slam and will allow more drop.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2009, 02:19 PM   #14
smashingchuck
here's a picture of what I was talking about.
78 Build Thread
4Runner Build
Old 02-13-2009, 12:18 AM   #15
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Dash over real fast to my build post 29 tall tires on the factory k- member like smashin is talkin about... Links in my sinature
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
Last edited by wicked_sky_gazer; 02-13-2009 at 12:41 AM. Reason: For got something
wicked_sky_gazer is offline   Reply With Quote
Old 02-13-2009, 12:25 AM   #16
Twisted Minis
Twisted Minis's Avatar
I would recess the bag into the lower arm. It's probably the most cost effective route at this point.
Firestone and Contitech bags do compress a good bit further than Slams do. They need to be limited in drop though with a bump stop. Slams have an internal bump stop, the rest don't. The slams compress to about 3", and the Contitechs are recommended to be limited to compressing 2.75".
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-13-2009, 12:44 AM   #17
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I "cupped" my LCAs & wont do it again
There is someone on here that welded a plate to the bottom of there LCAs & then cut the center out around the bag, I think this is a better way of modding the LCAs if you plan to lay out
The reason I dont like "Cupping" the LCAs is because when you dump the cups hit the ground first & thats not a good thing
Here are some pics of mine
And it will do this too (I have 28" tall tires on it)
Heres the only pic I could find of the plates I was talking about
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
