Door Problems
Hey guy not sure if anyone has had experience with this but only on my passenger side door it is quite hard to close. If it is lightly shut it will be closed but not fully, i was wondering what this could be cause this and what i could do to fix it.
"All Throttle No Bottle" 1984 C10 Stepper ![]() |
#2 | |
Re: Door Problems
Most of the time it is caused by worn bushings and/or pins in the hinges. The door "droops" and then the striker does not line up. This can also damage the striker mechanism and the latch pin itself.....but it usually starts with the hinges.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Active Member
![]() Join Date: Jan 2004
Re: Door Problems
Check the striker bolts where the door latches when you close it. It should have a plastic bushing on it and most of the time they're gone. If that's the case, go to the HELP section at an automotive store. They have a kit that has the size that will fit right over the striker bolt. You just have to remove the striker bolt, tap it on and then reinstall. It makes a huge difference and it should close all the way much easier, provided the door doesn't sag from worn out hinges.
Lane 1979 Chevy SWB- (Second owner- Father in Law was first) 1979 Chevy Silverado SWB-Red/Red |
Re: Door Problems
I will try that thanks alot for the advice guys!
Cheyenne Super
Re: Door Problems
Good reason to keep your hinges lubed.
If your having trouble finding bushings you can just move the top hinge forward on the cab just a little bit and that will pull it back up, but there is a snap in plug behind the dash vent (left of the headlight switch) that will have to come out before you can get to the inside bolt. The door will have to come off either way, so get a buddy to help you. |
