Old 05-13-2002, 04:41 PM   #1
flyin99
creator of kong
flyin99's Avatar
Question Question for you guys running TH700R4?
Did you modify your indicator, or does somebody make them for these trucks, that has the P R O D 2 1 type of indicator?
flyin99 is offline   Reply With Quote
Old 05-13-2002, 04:50 PM   #2
bigvinnie
bigvinnie's Avatar
Post
didn't modify it, my pointer lands on the D when I'm in 4th, rarely ever shift to the other 3 forward gears...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-13-2002, 04:53 PM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
I once saw an indicator for our trucks that had the OD / D / 2 / 1 indicators...I should've bookmarked it...I think I found it on a site in a thread regarding aftermarket gauges in the stock clusters...
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-13-2002, 05:26 PM   #4
Wasted Income
Boosted Member
Wasted Income's Avatar
Post
I simply do not have an indicator on my truck. The shift detents in the column work just fine with the overdrive. I believe that Dakota Digital has an indicator (L.E.D. or digital) that would work. Pretty pricey if i remember correctly (which is why i am indicatorless)
-Jeff
69 C-10 LWB
67 C-10 SWB
92 K1500 Burban
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-14-2002, 12:07 PM   #5
Blue68
Blue68's Avatar
Post
Running the stock 3sp column with a Lokar setup. I've been driving long enough to more or less guess where Drive is so its not a problem. Now when my wife gets in the truck (once every couple of years) it's a challenge since you have to pull the shifter towards you like going into reverse or first on the 3 speed column.
It's almost an antitheft device....
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Way too much money and time..But it's a hobby.
http://home.comcast.net/~r.landrum/w...tos.html-.html
Blue68 is offline   Reply With Quote
Old 05-14-2002, 12:11 PM   #6
Leinie
Post
I was looking at the column in a chevy van,(with auto od ) and it appeared to me that the indicator from that column might work.
Don't know for sure, but might be worth checking out.
Leinie is offline   Reply With Quote
Old 05-14-2002, 12:15 PM   #7
1-PU70
1-PU70's Avatar
Post
I used all the origanal parts from the 350 I took out. When it points to 3rd its in 4th. I can shift it past 1st witch is realy 2nd and use first only.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 05-14-2002, 12:20 PM   #8
Mixup
Post
I just put one on my 69. I got it from Bowtie overdrives. I-DID-IT makes it. I removed the old housing and the old indicator window. I had to grind the new one a little to slide in the housing from the back. It looks great and the light still shines through it.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-14-2002, 01:44 PM   #9
busterwivell
Post
Mixup, pictures? PLEASE!
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-14-2002, 04:21 PM   #10
Mixup
Post
No camara. I'll see if I can borrow one.
1969 Z28 engine
Turbo 350
