Old 02-07-2009, 08:55 PM   #1
pound41
? for those who have replaced their gas tank
On the old tank there are what appear to be spacers that sit on the top flanges of the tank.. They have rubber between them and the tank and rest against the frame. Is that correct? Anyway if thats what they are. I have missed placed one. Can I use any piece of flat metal Or do I eliminate them. What to truck guys do when they relocate the tank
Thanks for your help
pound41 is offline   Reply With Quote
Old 02-09-2009, 10:42 AM   #2
Burt4x4
Burt4x4's Avatar
Re: ? for those who have replaced their gas tank
I don't recall having rubber spacers on mine...I say just make both sides mount the same and run it. As long as it's secure yer good!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-09-2009, 11:33 AM   #3
bigdon-70blazer
My blazer had both of the metal spacers and the rubber as you described. The rubber looked like someone, at the factory, used cut up inner tube for this rubber piece and I do believe that they were only there for squeak reduction. I was able to use the originals when I put it back togather and reinforced them with... cut up parts of an inner tube! As far as going without the metal spacer, I don't know for sure but I would not know what would be wrong with that...
bigdon-70blazer is offline   Reply With Quote
Old 02-09-2009, 12:37 PM   #4
hotrodhomi
hotrodhomi's Avatar
I would cut a piece of rubber and replace it. Mine are still there. I'm sure it was for noise reduction and to reduce the chance of rubbing a whole in the tank.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
