Old 02-07-2009, 09:57 PM   #1
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Removing in Cab Gas Tank Supports
Are they pressed in or part of the cab itself? 62 pickup
Thanks for any help!
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 02-08-2009, 11:59 AM   #2
502tripower
502tripower's Avatar
Re: Removing in Cab Gas Tank Supports
Mack, just drill out the spotwelds and they will come right out.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 02-08-2009, 01:32 PM   #3
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Hmm okay I will take another look, but I didnt see them. Thanks!
350/350
2.5/5 static drop
Old 02-08-2009, 02:16 PM   #4
joe231
joe231's Avatar
you may need to use a flap disk or wire wheel to uncover the spots.
in the '64-'56'-66 they are part of the rear cab mounts and seem to add some rigidity to the back wall of the cab....
My thinking on my is to just cut off the front portion that sticks out for the tank to sit on.
not sure about the '60-'63 cabs
CHEVY ONLY
Old 02-08-2009, 07:36 PM   #5
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
I'm confussed. Is this what you are talking about.
Alan's Classic is offline   Reply With Quote
Old 02-08-2009, 07:38 PM   #6
DaddyMack
Wide Eyed User
DaddyMack's Avatar
here are the pics for anyone interested.
13 weld spots per bracket... if you add the four bolts holding it down..lol.. this thing wasn't going anywhere!... lmao.. talk about overkill.
Worth taking out IMO .. look at the rust lurking behind it!
Only one oopsy ... 25 partial holes and 1 oopsy..lol
350/350
2.5/5 static drop
Old 02-08-2009, 07:38 PM   #7
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Was. lol
350/350
2.5/5 static drop
Old 02-08-2009, 08:11 PM   #8
Alan's Classic
Are you just going to use a nut and washer on your cab mount bolt? Or is there other plans?
Old 02-08-2009, 09:09 PM   #9
protrash64
Resistance is Futile
protrash64's Avatar
You just removed your sub-box mounts..............!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-08-2009, 09:42 PM   #10
ol Curt
Junior Member
ol Curt's Avatar
ol Curt is offline   Reply With Quote
Old 02-08-2009, 10:13 PM   #11
TimE
Hey Y'all!!
TimE's Avatar
I'm curious about this too...
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-09-2009, 11:16 AM   #12
502tripower
Mack, Looks good. I did the exact same thing in my cab. Including drilling through the back of the cab in one place... and they looked about like yours comming out.... I just used a bolt and washer.
98' FXD
2002 2500HD
Old 02-09-2009, 11:21 AM   #13
joe231
joe231's Avatar
Originally Posted by 502tripower View Post
Mack, Looks good. I did the exact same thing in my cab. Including drilling through the back of the cab... and they lloked about like yours comming out....
Hey, what did you use for your cab mounts?
CHEVY ONLY
Old 02-09-2009, 11:25 AM   #14
502tripower
Damn your fast Joe..... Is there smoke comming off that key board....
98' FXD
2002 2500HD
Old 02-09-2009, 12:48 PM   #15
ol Curt
Junior Member
ol Curt's Avatar
If you're going to be the Sheriff, you have to be quick on the draw!!
Old 02-09-2009, 01:00 PM   #16
4dranch
Shloooooong bed member #2
4dranch's Avatar
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 02-09-2009, 06:41 PM   #17
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Hehe! Nothing that cant be covered I plan to just take a quarter inch flat plate to lay across from one hole to the next (on each side)... washer, lock washer and nut or perhaps nylocs.. either way...
LMAO!!! I discussed this exact thing with my kid..lol... BUT the rust I could see, plus, I am not sure exactly what seats, etc. are going in... Thinking.. 98 silverado... I wanted the room
BUT here is a question.... or thoughts....sand surface rust? then just spray paint using paint with a rust inhibitor? then coat entire bottom portion of cab with rhino liner before putting in sound deadener? or just use the rhino in the footwells? or ???? trying to figure out best way to treat it...most if it will be covered with carpeting...
350/350
2.5/5 static drop
Old 02-09-2009, 07:04 PM   #18
protrash64
protrash64's Avatar
I would do all of that. Sand, wirebrush, whatever you prefer. Im not sure what rhino liner can be sprayed on, but maybe self-etching primer. Rhino the whole floor .......fill in your threaded holes first.
Good to see you back on here with some updates.
Old 02-09-2009, 07:16 PM   #19
joe231
joe231's Avatar
Originally Posted by 4dranch View Post
What can I say?
Chief turned me on to this spray it yourself 2 part bedliner, U-POL Raptor, for around $120 you get a gallon, hardener, and even the gun. Have read good things about it on a jeep forum. you can't spray it on bare metal though, they recommend a good etching primer on any bare metal. I think I'm gonna use it on the underside of the cab along with inside on the floor.
here is a link to one site that sells it
http://www.tptools.com/p/2600,233_U-...Liner-Kit.html
CHEVY ONLY
Old 02-11-2009, 07:20 PM   #20
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Originally Posted by joe231 View Post
What can I say?
Thanks Joe!
That stuff looks perfect... and will make a good mess...lol
350/350
2.5/5 static drop
Old 02-11-2009, 08:24 PM   #21
joe231
joe231's Avatar
CHEVY ONLY
