Old 02-07-2009, 10:56 PM   #1
john02fxdl
HELP! Wheels hitting calipers
OK, so I just did my six lug disc brake conversion today on ECE drop spindles on my 70 stepper. I went and mounted my wheels and they won't turn! So I take them back off and sure enough, it's the caliper hitting the wheel. These are stock steel wheels, not aftermarket. I can get them to clear w/ a 1/4" wheel spacer, but WTF? Has anyone else have this problem and what did you do to correct it? I didn't really want to buy new wheels, I'd rather keep my stock steelies for the old school look
john02fxdl is offline   Reply With Quote
Old 02-07-2009, 11:00 PM   #2
chipflyer
chipflyer's Avatar
Re: HELP! Wheels hitting calipers
Your going to need the 71-86 or 87 (can't remember which year they changed) six lug steel wheels, they have a deeper offset than the older wheels to clear the calipers.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 02-07-2009, 11:04 PM   #3
Cyclone
Cyclone's Avatar
Do a search here, theres been lots of posts about grinding the calipers for clearance. Many 4x4 builders grind the calipers for 15" wheel clearance.
Cyclone is offline   Reply With Quote
Old 02-07-2009, 11:11 PM   #4
jc
jc's Avatar
4x4 71-72 blazer wheels should work but i think it will bump out your tire 3/4 of an inch on each side.
i have a set for sale if you need em .
zip is 08527 there somewhere on the parts board . if wanna go that route ill send you a link
(edit) heres the link
http://67-72chevytrucks.com/vboard/s...d.php?t=317824
2004 Silverado 2500HD Crewcab 4x4
2000 TOYOTA 4RUNNER
1971 CHEYENNE LWB (THE LOVE SHACK)
1967 c-10 lwb (THE FARMERS DAUGHTER)
jc is offline   Reply With Quote
Old 02-07-2009, 11:30 PM   #5
chipflyer
chipflyer's Avatar
Careful with that caliper grinding to clear the old wheels, it may not be that great of an idea to grind on something that is so critical to stopping your truck. When Disc bakes became available in 71 GM didn't just grind the calipers to make them fit, they redesigned the wheels to clear the calipers. There are lots of 71 and up 1/2 ton 6 lug 4x4 wheels out there.
Just something to think about.
Jeff
Old 02-08-2009, 12:02 AM   #6
cdowns
cdowns's Avatar
later wheels is the answer the early wheels both 5 and 6 lugs are cars and trucks have different construction and dont clear disc brakes// grinding calipers IMO BAD IDEA
Old 02-08-2009, 08:50 AM   #7
Andy4639
Old member
Andy4639's Avatar
Do it right and do it safely for you, your family and my family please. Buy new wheels.
As stated above Chevy didn't grind the caliper's for the 71,72 models.
I know buying more wheels wasn't in the plan but it's the right thing to do. Spacers are better than grinding but the wheels would be the answer.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-08-2009, 08:56 AM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Throw some six lug ralleys on there, they look cool and still give it the old school look.
--Josh
Old 02-08-2009, 09:08 AM   #9
70jnktrk
70jnktrk's Avatar
Six lug ralleys...ESC dropped spindles on the front...stock wheels will not clear.
70jnktrk is offline   Reply With Quote
Old 02-08-2009, 09:13 AM   #10
70cst
70cst's Avatar
Bingo...as has been said 70jnktrk;3131373 is spot on. I ran into the same isues when I dropped my truck 2/4. I also had rubbing issues with factory Rally's but only on sharp turns. I ended up buying a set of used Torq II's off this forum. Problem solved.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-08-2009, 09:36 AM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Not to Hijack but I would appreciate a where/how on the wheel covers.I don't like the 6 lug center caps but don't have the 'nubs' for hubcaps.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-08-2009, 09:39 AM   #12
70jnktrk
70jnktrk's Avatar
Mine are Wheel Vintiques {spelling?} from Summit..outstand/fast service..nubs for police caps are there....hope this helps
Old 02-08-2009, 12:55 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
When I pulled the Wheel Vintiques off of my truck for the body/paint, I purchased a set of 6-lug wheels off of a '61 for 20 bucks. All good wheels. Took them and bought a set of used tires and had them mounted. When I went to pick up the truck at the tire shop, the front wheels were still on it, and the ugly wheels were on the back. yep, same problem you had. I found two of the 73-87 style spoked 4wd 6-lug wheels for 30 bucks and had the tires mounted on them. They cleared the calipers.
Member Nr. 2770
Old 02-08-2009, 01:12 PM   #14
sick69
sick69's Avatar
The early wheels are for drum brakes, which have a different shape on the inside of the wheel than disk brake wheels. You'll have to use later wheels(71+) or aftermarket.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-26-2020, 09:06 PM   #15
SouthernRodder
Guys thanks for all your input. I can assure you that I won’t do anything to jeopardize mine or my family’s safety. I have two girls that both love hotrods. I want them to have fond memories of the truck in there childhood just like I have.
SouthernRodder is offline   Reply With Quote
Old 01-30-2020, 10:44 AM   #16
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: HELP! Wheels hitting calipers
Old 01-30-2020, 12:07 PM   #17
The right wheels, '71-'91 4wd, will do the trick. But on grinding rotors, I know to fit 15" wheels on a 3/4t truck all you do is grind the casting ridge which is excess material. The radiused area that conforms to the wheel 'peaks' at that ridge and you just flatten it out some. Still more material in that area than the rest of the caliper. I did this years ago with no adverse affect what so ever.
Old 01-30-2020, 07:41 PM   #18
BigBird05
X2 for special K, In the past I have ground Calipers. Your not grinding the back side were the piston is. Your grinding the top front(outside) and only grinding a little. We had to do it when I worked in Experimental @ GM. We didn't have any new wheels to use yet. But for the look of a restored truck I would buy new wheels.
BigBird05 is offline   Reply With Quote
