Shock Absorber Mount ?
Working on a SWB 68 frame. Trying to get it ready for the road. What is the fix for the upper front shock absorber mount? The hole in the frame is to big from ware or just to many miles. What do you guys use to fix the problem?
69 swb stepside, rebuild and upgrade in progress |
Re: Shock Absorber Mount ?
i've always just weldedit in place to fix the problem
Under Construction
I agree with cdowns, weld it, I have seen washers welded in as well to allow the shock mount to bolt up.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Tasty Cakes!
Or if you're not a welder, ECE makes a kit to strengthen up that area that is bolt on IIRC.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Old member
I made my own mounts. I had lowered the truck but I wanted to use over the counter shocks for it so I made some mounts bolted them to the frame and they are a little taller than the frame rail.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Early Classic Enterprises and Classic Performance Products sell a kit to bolt mounts to the top of the frame.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
