Old 02-08-2009, 03:34 AM   #1
asbill71
lowering my 78
I have a 78 blazer 2wd. It has 2 inch drop spindles. Everything else in stock. I want to go a little lower. Is the best way to use 2 inch drop springs and shackle and hangers out back?
here is how it looks now
asbill71 is offline   Reply With Quote
Old 02-08-2009, 03:44 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: lowering my 78
the spring hangers are a hassle to install, also the shackles you will have to modify the filler hose, a flip kit would be the easiest and cheapest
http://store.summitracing.com/partde...5&autoview=sku
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-08-2009, 09:53 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: lowering my 78
Or take a leaf or two out, One long one and the over load.
tvblazer78 is offline   Reply With Quote
Old 02-09-2009, 12:51 AM   #4
asbill71
Re: lowering my 78
are hangers and shackles the same for a pickup and a K5 blazer of the same year?
Old 02-09-2009, 07:43 AM   #5
tobiahr
tobiahr's Avatar
Re: lowering my 78
No. The shackles will bolt up but contact the gas tank filler neck on the passenger side. The hangers bolt holes match but you will have to cut holes in the bed floor as they are to tall. like flaming and tvblazer suggested, either a flip kit or remove leaves.
tobiahr is offline   Reply With Quote
Old 02-09-2009, 10:35 AM   #6
cochino12
It followed me home?
cochino12's Avatar
Re: lowering my 78
Depending on how much drop you want I would start by taking a leaf or two out. I installed a flip and ended up getting about 8" of drop
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-09-2009, 01:06 PM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: lowering my 78
Yap, I did that same thing years ago..
Old 02-09-2009, 05:09 PM   #8
kevinr1970
Re: lowering my 78
You did a flip with newer (92-98?) K5 Blazer springs to get ~3" drop correct?
Thats what I am planning with mine, whenever that project gets put in the rotation...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-09-2009, 08:23 PM   #9
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: lowering my 78
Yep, they came off of a 93 2door 4x4 blazer..
Old 02-11-2009, 03:32 PM   #10
blazn79
Re: lowering my 78
Oops, your talking about the rear springs not the front!
H.FOR LIFE!
blazn79 is offline   Reply With Quote
Old 03-08-2009, 11:02 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
Re: lowering my 78
I'm not that handy, but a good friend is. Here's a shot of the modified tank filler tube he cobbled together for my Blazer that clears the drop shackles no problem.
