Old 02-08-2009, 04:54 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Truck or Van tilt? Cruise Control?
I picked up this column locally, and PO cannot remember what it came out of. The stering wheel was a factory black one, as would be on a truck or van. The center horn cap was missing though. I think it is out of a truck, as the neutral safety switch looks to be in the right spot, and I do not think the shaft has been collapsed. The rubber boots look like they are from our trucks also, and the U-shaped plug matches. It looks like it will match up to the non-tilt column I have in my C-20 now. I have power steering already...will this match up to the lower steering shaft already there with the non-tilt?
Also, the hazard switch is red (haven't seen that before on a tilt), and there is a cruise control turn signal lever on it. Is this from a factory cruise set-up? Thanks.
leddzepp is offline   Reply With Quote
Old 02-08-2009, 04:55 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Truck or Van tilt? Cruise Control?
pic
Old 02-08-2009, 06:44 AM   #3
JimKshortstep4x4
The column will fit your truck with no issues with the steering shaft.
I have not seen a red flasher button on these tilts. I have picked up a couple of Van tilts with the cruise handles on them so the truck tilts like yours could have come with the cruise.
Good find!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-08-2009, 09:54 AM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Truck or Van tilt? Cruise Control?
Looks like a real truck tilt to me.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-08-2009, 10:06 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
real truck tilt
cant explain the 4 way button
the cruise switch is a replacement for the broken original, it is a common generic GM piece used all through the 70's
Old 02-08-2009, 10:10 AM   #6
1970cstblazer
Wink Re: Truck or Van tilt? Cruise Control?
Most of the Pontiac models (non column dimmer)used that turn signal lever when optioned with cruise.
Old 02-08-2009, 10:12 AM   #7
70Custom10Nut
70Custom10Nut's Avatar
It's a truck column alright. The van column has a larger mounting plate at the firewall and the column housing is much shorter. I believe chevy used the red hazard knob up to 70 and then went to the black with the set screw (though I could be wrong) The cruise is what really has me intrigued. I've never seen one on this year group column, it could have been a dealer installed option. Cnut
70Custom10Nut is offline   Reply With Quote
Old 02-08-2009, 10:19 AM   #8
chipflyer
chipflyer's Avatar
The cruise switch is exactly what Longhorn man said it is. You can find that lever/switch in certain GM cars and trucks up until around 1976. It isn't original to 67-72 trucks. The column looks to be a truck column to me.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 02-08-2009, 12:15 PM   #9
71 super
71 super's Avatar
Truck column, switch has been changed out (cruise- stock replacement- if buying new now about $180 bucks) the turn signal switch looks like it may have been changed out at some point to explain the red hazzard knob.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-08-2009, 06:21 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Thanks for all the info guys! I will be putting this column in my C-20 tonight. I will not be putting cruise in it, so hopefully I can sell the switch.
Old 02-08-2009, 08:36 PM   #11
463
463's Avatar
Originally Posted by Longhorn Man View Post
real truck tilt
in the Canadian trucks up to 1972 had a red or fade to orange 4 way button,as did some of the 1970-2 USA built gmc trucks i had (explained the USA built 1970 gmc 1/2 ton came to Canada with a six lug setup and the Canadian built came with a five lug setup) in 1973 gm went to the black two piece 4way button.
Trueman
463 is offline   Reply With Quote
Old 02-09-2009, 12:34 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I talked to the PO again, and he seems to think this column may have come out of a 1970 CST. I did some research, and it seems that the red button came on trucks up till 1970? I pulled it apart, and it looks like it has been there for 40 years.
Old 02-09-2009, 01:19 PM   #13
ERASER5
ERASER5's Avatar
Sell the switch? No way! You need that switch to engage your secret NOS system!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 02-09-2009, 02:48 PM   #14
leddzepp
Moderator
leddzepp's Avatar
Now that's a great idea! I am going to sell it to fund other parts needs....here is a link to my WIW thread, thanks. http://67-72chevytrucks.com/vboard/s...22#post3133922
Old 02-09-2009, 04:08 PM   #15
68350
68350's Avatar
another easy way is the plug in. van are straight while trucks are curved.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 02-09-2009, 04:38 PM   #16
leddzepp
Moderator
leddzepp's Avatar
This is true, but the plugs can be swapped out fairly easy.
Old 02-09-2009, 04:39 PM   #17
Longhorn Man
early van units were curved on the plug, so that's not a 100% sure fire way to tell.
I've never heard that disc brakes came in canadian 1970 trucks... no documentation, nor photographic proof. You sure yours wasn't swapped out?
Old 02-12-2009, 03:57 PM   #18
truckintexas
It's definitely a truck column and the red 4-way pull indicates it could be from a 70 Model. My 70 CST had the same column.
truckintexas is offline   Reply With Quote
