Fuel sender question.
short version
I have a 71 c10 that came stock with a 350 engine. I'm new to Chevys so this could be a dumb question but I need to know if I need to buy a 4bbl or 2 bbl fuel sending unit so I can get my truck back on the road. Long Version I aquired a 71 c10 that has a great drive train but everything else was pretty much garbage (except the body). I replaced all the axle seals, brake lines calipers roters drums pads shoes and installed a booster. I finally got it rolling, insured and put a tag on it and the thing conks out on me about 20 feet from my drive way. This truck has been my buddy every since knowing it could have gave up waaaay beefore I got home. The issue. Old gas, rusty tank, and sending unit. I've got the tank cleaned lined and ready to go back in, but I can't figure out if I need a 4bbl or 2 bbl sending unit. It came stock with a 350 engine. Thanks for the help. Rod |
Active Member
![]() Join Date: Jul 2007
Re: Fuel sender question.
I didn't know there was a difference... Only differences I've seen is that vented non vented and the six cylinder or v8 ones. V8 has a larger diameter tube if I remember correctly.
Active Member
Here's GMCPaul's site on them. He's a local vendor. There are others that suport the site also.
http://www.gmcpauls.com/fuel_tank_&_related.htm |
I wanted to assume that the 6 cylinder ones were probbably 2 bbl and the v8 was 4bbl but I didn't know. After visiting the local parts store and seeing about 5 different varioations I didn't want to chance it. Don't have a lot of cash to spend on restocking fees and shipping back parts...
#5 | |
Thanks for the link, it was actually a few dollars cheaper than LMC! I didn't expect such a quick response either, you guess get an A for Awsomeness. |
