Old 02-08-2009, 12:30 PM   #1
BluTrukker
BOHICA
BluTrukker's Avatar
No trim
Could you order a truck in 68 with no moldings? My 68 LWB is about as basic as it comes. The only option on the SPID is heavy rear suspension. It has the original 307 w/3OTT. The PO repainted it. I would like to put the correct lower side and tailgate trim on it. There are no trim holes that I can see, and if the PO filled them in he did a pretty good job as I can't find any evidence of this. If it never had any holes to begin with, do I have to drill them or is there stick on trim available?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 02-08-2009, 12:36 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: No trim
Upper/lower side moldings were an option. In '67-8, the trim followed the body break along the lower body and over the wheel openings.
Unless the SPID says it had bodyside trim, the P.O. probably didn't fill any holes. I also believe that year had the kind of trim attachment that used holes in the body. Later models (71-up) had adhesive attachments.
I have removed my side trim, upper and lower, and the holes will be filled.....weird, huh?
Member Nr. 2770
Old 02-08-2009, 12:50 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: No trim
Mine had the molding but I've seen them without. In those days you could just about order any option or absolutely no option on them that you wanted.
As for the other question, I think I've read on this site that you can do it either way -redrill holes or stick. However, in my opinion, seems that the molding on the 68's would be a lot harder to do with the glue/stick method.
forgot to add: I've never seen "stick on" trim available.
68gmsee is offline   Reply With Quote
Old 02-08-2009, 01:00 PM   #4
Andy4639
Old member
Andy4639's Avatar
Re: No trim
My 71 had the holes down the sides. I welded them up this last time.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-08-2009, 02:15 PM   #5
BluTrukker
BOHICA
BluTrukker's Avatar
Re: No trim
ChevLoRay So would the 71-up lower side and tailgate fit on a 68? I don't want to drill if I don't have to.
