![]() Join Date: Apr 2004
Anyone install their trim with tape?
Anyone install their trim with tape? Almost all new cars have the trim taped on, is there any reason that it shouldn’t be done to our trucks?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Grandpa in the rustmobile...
Re: Anyone install their trim with tape?
well....
taped on huh thats a first... by golly imona camerflauge tape my triummm bak on scooter!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I bought lower woodgrain trim from GM in 1990. In some areas, they provided clips with a 3M adhesive backing. I never could get them to adhere well, and I wound up using the standard "all metal" clips. Of course that was 1990. I'm sure adhesive products have improved since then.
As I recall some of mine were a mixture of the tape and metal fasteners. To be honest the tape seemed secure enough but I didn't like how far it stood off the body surface.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Did my Blazer's trim with 3M's tape.
Still holding strong 5 years later. ![]() ![]() ![]() ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() ![]() Join Date: Jul 2003
I reuse the original plastic GM clips, and buy the adhesive tape by the roll from 3M.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Active Member
![]() Join Date: Feb 2000
I've used the 3m tape in the past and its held up fine on a truck I keep garaged.I'm going to use it on my GMC that stays out as soon as I get my stripes painted on the sides, then apply the 3m tape. I don't want to drill holes in a truck that never had them and sits out in the weather to rust..
We'll see how it goes.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
there is a differance in 3m tape. its defined by the color and i think the gray is what you want for this application
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
Active Member
Good to know.
I think what I used a few years ago was red, but maybe the part that peeled off was red. In any case I'll be buying new stuff and I'll check on that color you mentioned-don't need my trim falling off during the first rain storm.
![]() Join Date: May 2005
I've used the 3m tape on occasion, and I've found that if you wipe the area with some rubbing alcohol prior to applying the tape, you'll get a good strong bond.
Pete |
Like a Rock!
The tape Bobbyk posted is the good stuff.
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Why not just use the clips ? They held the trim on for 30 yrs...+ you Can remove them without bending the trim up and having to clean all the residue from the tape off if you ever repaint or repair any parts.
#13 |
I not sure I want to drill holes
#14 |
i used 3m tape on my trim for my lower of my bed..held strong with no problems
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#15 |
the factory used tape to apply trim on my 87. Most of the trim is still on there. All of it would be on if it hadn't been caught on tree limbs and such. the only thing is that it creates a place for water to sit and rust the metal. on the places where the trim has come off on my truck, you can still see the adhesive and pitting where the water sat. but the same could be said about the holes and clips. my metal cab trim below the back window on my 69 caused areas to rust, so it's a toss up. the tape should hold excellently though. Trim is just an accent, so who cares how it's applied? It's not like you're trying to use bondo to make a fender.
#16 |
One other point, what if you end up changing your mind about the trim at a later date? Adhesive will be a lot easier to clean off than holes will be to weld up. Just a thought.
#17 |
BobbyK, can you tell me what the ID is on that 3M tape? I work for a wholesale distribution company. We buy directly from 3M almost every week and I wanted to see if its something I could get a sample of to experiment with.
#18 | |
#19 |
454 MAKES IT ROAR
My trim was already fitted with a combo of the original metal clips and the tape, and when I needed to replace my damaged trim the replacement trim came with new adhesive strips and they have not held as well as the stuff I had to remove. And as has already been mentioned the adhesive pads held the trim to far off the body for my liking. I'd say the tape would be fine if you don't want holes in the body where there were none to begin with but it would be real important to get the best available tape out there, imagine the wind getting behind it on the freeway and tearing it off....what about heavy duty Velcro?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#20 | |
It came in a plastic bag with no product numbers on it. I do know they sell it in 5' rolls in the parts stores for around $8.00 bucks.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 02-09-2009 at 10:57 PM. |
#21 |
