02-08-2009, 03:33 PM | #1 |
cutting springs
I have bought the ECE 2/4 drop springs and put it on my 6 cyl long box gmc truck and it looks funny it looks higher in the front than the rear I was thinking of cutting out 1/4 to 1/2 a coil to get it down just a bit to have a slight rake in the front. has anyone cut drop springs? how much is safe to cut out? I was thinking 1/2 coil. any help would be great thanks
02-08-2009, 06:05 PM | #2 |
Re: cutting springs
I'ld drive it as is for awhile. Some brands of coils have a tendency to settle a bit after their drove for awhile.
02-08-2009, 07:13 PM | #3 |
Re: cutting springs
Coils won't fit the spring pockets correctly unless you cut exactly 1 coil off, they index on top and bottom. Some have done it, like 1/2 coil, but its not going to fit right, and likely make some noise as they shift around. A big block would set the front end right where you want it.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 02-08-2009 at 07:16 PM. |
02-08-2009, 07:34 PM | #4 |
Re: cutting springs
you could try heating them with a hand held propane torch instead of cutting
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 |
02-09-2009, 01:19 PM | #5 |
Out of the carpool lane.
Re: cutting springs
1/2 coil will be ok, just be sure to index them both at the top and use a cutoff wheel in a grinder, not a torch to cut them.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
02-09-2009, 01:55 PM | #6 |
Re: cutting springs
a propane torch isn't gonna get anywhere near hot enough to cause a spring to collapse ... besides, heating springs is about the WORST thing you can to do one.
02-09-2009, 02:20 PM | #7 |
Moderator
Re: cutting springs
02-09-2009, 02:32 PM | #8 |
Re: cutting springs
02-09-2009, 02:54 PM | #9 |
Re: cutting springs
Ya I kinda thought it wouldn't be a good Ideal to heat them, a friend of mine heated his springs on his 69 c10, I ask him if that was a good Ideal to do, he said it wouldn't mess things up, it was the easiest/cheapest way to drop the truck,, but anyhow I'm putting bags on mine,, sorry for the bad suggestion, ,
02-09-2009, 03:08 PM | #10 |
Re: cutting springs
Cut 1 coil is worth about 1". I would drive it for awhile and let it settle. NEVER EVER heat the coil it is a crummy ride.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
02-09-2009, 03:28 PM | #11 |
Re: cutting springs
Been there done that, back in the early 80's I had a 67 short stepside. Got the bright idea of heating all 4 coils to lower it. It looked good, but rode like a log wagon. Not recommended at all. I ended up putting 4 new coils under her.
68' SWB 355 CID since 1987 89' S15 4WD 4.3 08' VTX 1300R 08' Chevrolet HHR (Wife's ride) "That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage. |
02-09-2009, 04:58 PM | #12 |
Re: cutting springs
actually, 1 full cut coil is good for approx. 2" - 2 1/2" worth of drop
