Old 02-08-2009, 04:55 PM   #1
pete29
suggestions for new alternator and battery
i'm needin to upgrade my alternator in my 72 chevy 3/4 ton with 350 because i'm putting subs and an amp in it. I'm wanting to get an internal regulated one with the one wire hookup i think. I was hopin to get like a 140 amp alternator to power every thing because its a big amp. Should i get a different battery to, cause i've heard its a good idea with that big of alternator
pete29 is offline   Reply With Quote
Old 02-08-2009, 05:37 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: suggestions for new alternator and battery
I would post this over in the Audio area. You will get more help on what you need.
Yes go with a bigger alternator but a 3 wire is better I think than the one wires in my opinion. Here are a few links for you, the first explains the mod for alternator.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
http://67-72chevytrucks.com/vboard/f...play.php?f=111
This could help to.
http://67-72chevytrucks.com/vboard/f...splay.php?f=64
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-08-2009, 05:59 PM   #3
manimal
manimal's Avatar
cs130 or cs144. There are many write-ups for this. Check the FAQs. I can do a step by step if you need it. Good Luck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 02-08-2009, 10:50 PM   #4
fixit-p
fixit-p's Avatar
I would go with a delco 12 si its good for 94 amps also check out mad electrical http://madelectrical.com/electricalt...hreewire.shtml
fixit-p is offline   Reply With Quote
