Grandpa in the rustmobile...
Need some parts but not sure what exactly I need..can someone help..
Okay, I washed the truck today in the 70* weather we had....I opened the door to get in and the interior was wet...I decided It was finally time to order new door/window seals..
The water goes down the window into the inside of the door (cannot be good!)..the seals around the door and cut, dryrotted and worthless... I DONT want to order front windshield or back glass seals, ive already got those thanks to a genrerous board member... I need: All Seals For Drivers side door and windows all seals for passenger side door and windows and possibly something to keep the windows from shaking terribly!! Also, my windows rattle very bad when going over rough ground or going down the gravel driveway....the shake and are very loose...what do i need to fix this, some sort of felt lingin in the windows??!! Thanks it'd be greatly appreciated if somebody could tell me exactly what i need...cant find exactly what im looking for on the internet sites... THANKS ALOT FELLAS!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Need some parts but not sure what exactly I need..can someone help..
try this site/catalog it has pretty much everything you need and mostly cheaper then anyother site/catalog , http://<br />
<br />
http://www.tr...t60_cover.html
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 ![]() |
oops,, here it is >>> http://www.truckandcarshop.com/truck...t60_cover.html
Between Trucks...
As far as door seals go, I definitely recommend the press on type ones that GMC Pauls has. No messing with glue and you can remove and reinstall if you need to for paint or something.
Beat it to fit, Paint it to match... ![]() |
is that door AND window seals,
thanks sinister, oh and btw thanks for that windshield seals again, im still lettin it drip on my dash but thanks for when i get it put on!!
Between Trucks...
No problem. I got the door seals from him. He's got the rest as well.
okay ima get the push on stuff
does that include the vent window seals too??
Between Trucks...
Nope just around the doors.
![]() Join Date: Nov 2003
I got the push on stuff but the doors always shut very hard after that. It's considerably thicker than stock. It was nice because it was easy to put on, but I don't think I would get it again. I would try something like part number 132051 on here:
http://www.gmcpauls.com/Pickup.htm It is $65 and has everything for the doors, including the parts to stop your windows from shaking.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
okay...that 132051 was on my list of things to buy...
but im getting different opionons on the weatherstripping, press on vs. the other kind i guess lol... lets get some more opinions here folks! im all for easy! lol
Never used the press on before but sounds easy enough though.
If you use the standard stuff you will need the 3 M sealant availabe at most parts places. Always had better luck using the black color and plenty of clothes pins /or tape as clamps. The vent windows seals are for the more challenged. Good luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
thanks lots guys gonna order here tnoite hopefuly
#13 |
Theres a FAQ in the index for re building your vent window..Its a PITA from what ive heard but well worth the better sealing
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
