Old 02-08-2009, 09:57 PM   #1
Lionc68c10
Lionc68c10's Avatar
Question Question, No response when turning the key.
Some times when attempting to turn my truck on I will turn the key and nothing will happen. I will sit there and try again and nothing. The third time the truck finally starts. Then the next time she will turn right on with no porblem. This past month the cycle of three tries to turn her on is more common. My lights still work when the car will not turn on, I tested the inside and head lights and all works good. Finally today the truck would not start at all no matter how many tries. I had to get a jump and it started right up strong. I already did the battery test where I leave the truck running and take off the negative battery, the truck still runs which indicates the alternator is good. I have replaced the battery about two months ago. I just went outside and she started right up with no problem. It's an on and off problem that I can’t figure out. Any suggestions?
Lionc68c10 is offline   Reply With Quote
Old 02-08-2009, 10:20 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Question, No response when turning the key.
Sounds like your starter solenoid might be getting weak or the starter has a flat spot. It could also be a bad connection or bad ignition switch. That's the bad thing about this type of problem. I would start with the cheapest fix. Taking both ends of the battery cables off and making sure they are clean...
LockDoc
Leon
Old 02-08-2009, 10:24 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there's all kinds of things... try wiggling the shifter next time (assuming automatic)
Old 02-08-2009, 10:36 PM   #4
Kayotic
Kayotic's Avatar
I am liking the response from LongHorn Man. All your checks seem fine so far, I would take a good look at the shifter... Again being an auto.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-09-2009, 12:03 AM   #5
Green Machine
Green Machine's Avatar
Next time it acts up, try tapping the starter with a hammer. I have had several over the years that had worn out brushes in the starter.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-09-2009, 12:09 AM   #6
tim21391
tim21391's Avatar
had this happen to me this past summer... my battery got too hot when it was cranking... which in turn fried the starter... i got a new battery and new starter in the long run
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 02-09-2009, 12:28 AM   #7
fine69
fine69's Avatar
In the past i have had a bad ignition switch.
Rare, but if all else fails.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 02-09-2009, 12:45 AM   #8
vectorit
What?
vectorit's Avatar
When my burb had headers I had the same problem, and after checking all of the things one would check for this issue I still had the gremlin.
Turned out that one of the selonoid wires cooked from the header pipe, it wasn't burned bare but just enough to cause issues.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-09-2009, 06:43 AM   #9
Longhorn Man
see... it could be ANYTHING
Old 02-09-2009, 09:45 AM   #10
Lionc68c10
Lionc68c10's Avatar
Thanks for all the suggestions, atleast now I have some direction the next it happens I will try the shifter trick and hit my starter with a hammer. Then slowly one by one from cheapest I will start replacing parts. I will provided an update, thanks!
Old 02-09-2009, 09:50 AM   #11
greygoose
greygoose's Avatar
Could this be a GM flaw,I've had two Cadillac at different points that have done the very same thing to me.I ended up trading one and sold the other.
If it ain't a chevy,I don't want it
greygoose is offline   Reply With Quote
Old 02-09-2009, 10:25 AM   #12
theyammieguy
accepting donations
theyammieguy's Avatar
Don't mess with the shifter and hit the starter. Do one or the other. Sometimes finding the problem is as simple as the process of elimination.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 02-09-2009, 02:26 PM   #13
tim21391
tim21391's Avatar
try to bypass the starter it worked on a customer car i worked on at my job
Old 02-09-2009, 09:43 PM   #14
Lionc68c10
Lionc68c10's Avatar
All,
I have tried all the little tricks and tests. No luck, so the last thing to due is replace the Starter along with the Starter Solenoid. I will attempt to change it out myself wish me lucky
Old 02-10-2009, 01:55 AM   #15
joemacho
joemacho's Avatar
to check if your starter is good take it out and connect jumper cables to it ground out the but end on the starter and connect positive on the middle of the solenoid touch the screw where you connect the ignition wire see if it spins. if spins it is good. also replace the ignition switch they go bad and sometimes remanufature ones go bad. This happend to me i went through 3 ignition switches finnaly the last one worked no problems any more.
joemacho is offline   Reply With Quote
Old 02-10-2009, 02:06 AM   #16
sflanagan
sflanagan's Avatar
A bad voltage regulator can make things act funny too...and again sometimes the remanufacterd ones are junk too...good thing they are only 4 bucks...just another piece to the tangled web and magic of wiring problems...good luck
-Sean-
68 Chevy fleetside/shortbed, 350 eng., alum. heads, 10 to 1, 430 hp.
sflanagan is offline   Reply With Quote
Old 02-10-2009, 02:29 AM   #17
spinning wheels
spinning wheels's Avatar
Did you check the voltage of the battery? When you jumped it, it started right up. You may have a low voltage battery or your alternator is not charging your battery like it is supposed to. Removing the battery cable when the engine is working, was a way to check to see if a generator was working properly. Next time, when the engine is running. Check the voltage that the battery is getting. Usually 13 1/2 volts. Rev the engine, the voltage should go up, then settle back down to 13 1/2 volts, when you ease off the gas.
If your alternator is working correctly, and your battery has 13+ volts. Check your starter, they can go out with little warning or start dragging and get progressively worse.
One other item you might look at, are the battery cables. If they are old, replace them so that you have a good ground and a good positive.
These are problems I have had in the past. Not all of the problems have occurred in GM products. Stuff happens when it gets old.
Please post when you get it fixed and Good luck.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 02-10-2009, 03:02 AM   #18
cdowns
cdowns's Avatar
check the two purple wires at the neutral safety switch near the bottom of the column and clean the connections and make sure they're tight
Old 02-27-2009, 04:13 PM   #19
Lionc68c10
Lionc68c10's Avatar
FINALLY!!!!!! She is starting up like a CHAMP!!!
The first starter was bad, the second one was the winner. The truck is now running great so far and starts right up. Also, I went to an auto store and bought some engine boosters liquid and cleaner to add when I fueled the truck. I can remember the name, but I will find out. This stuff seems to have made my trucks engine sound better over all. Thanks for everyone's help!
Old 02-27-2009, 04:17 PM   #20
BluTrukker
BOHICA
BluTrukker's Avatar
Glad you found it, i had the same issue a while back and it took me forever to figure it out.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
