Ideas on how to hide wiring harness any pics?
My brother has a 68 and wants to get rid of the wiring harness reroute it to move it away from the firewall so it can be as smooth as possible any ideas or pictures would help thanks.
![]() Join Date: Sep 2006
Re: Ideas on how to hide wiring harness any pics?
I use my kick panel vent when i did my on the cowl on the side i cut a access hole that line up with the vent hole then cut me a panel that fit the vent i use body caulk and sheet metal screws then ran my wires down the back you can run the headlight wires beside the fender and the engine are down low and comes across the back of the motor, the tail light wire are in the same location you have to drill a 1" hole to put it threw. when the is put on you cant see the wirimg or te access hole
Chevy Truck Addict
![]() Join Date: Aug 2006
I ran my engine harness straight down from the fuse block, then across behind the lip on the underside of the firewall. You can see in the one photo where I have some heat shield across the top of my exhaust. I used nuts and installed wire retainers on the bottom of a few bolts that hold the hump in place. This keeps the wires up nice and tight (everything is in wire loom of course). Also, I drilled a few holes in the topside of the cowl, installed rubber grommets and ran my washer hoses straight up to the nozzles instead of bringing them out the factory hole and running them across the firewall.
Here are some pics
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
the pic above is what i call overkill
My friend who rewired my whole truck ran the wires thru the inner lip of the fender and thru the bottom of the core support, a/c lines thru the air vent.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
i tried to hide mine the best I could...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
Tell him to go wireless! Everything else is.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
