Old 02-08-2009, 11:37 PM   #1
oldspowered
resto body guy
fuel injection question
i'm installing my 87 tbi 350 motor and 700trans in my 71super cheyenne truck well i want to know if the fuel sender from the 87 chevy truck will work with the 71c-10 gas gauge?? i'm planning to install a new full size blazer tank so the sender should work. i just need to know if i need something else??
any tips are welcome..
http://i3.photobucket.com/albums/y86...DSC_0004-2.jpg
trucks are ment to haul!
oldspowered is offline   Reply With Quote
Old 02-09-2009, 12:16 AM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: fuel injection question
i think it should we just put a sender from a 91 sub in an 81 pickup
jbristo67 is offline   Reply With Quote
Old 02-09-2009, 12:18 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hook an ohmmeter between the center terminal on the 87 sender and the mounting flange and if it reads 0-90 ohms as you move the arm full down to full up then it should work.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-09-2009, 12:26 AM   #4
extd56
extd56's Avatar
It will work as I am using a 88 fuel tank in my 67
extd56 is offline   Reply With Quote
Old 02-09-2009, 03:36 PM   #5
Andy4639
Old member
Andy4639's Avatar
I'm using a 93 suburban tank and sender in my 71 and it's hooked to the factory gauge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-09-2009, 07:12 PM   #6
svgould
Active Member
svgould's Avatar
What modifications where done to make an 88 fuel tank fit? That would make fuel injection a breeze!!
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 02-09-2009, 07:17 PM   #7
extd56
extd56's Avatar
I am using a Blazer 31 gallon tnak and used the crossmemers out of the 88. It fits great but might not work in a shortbed as it is in a longbed now.
