spot weld bit size
Guys who've replaced rocker panels - what's the correct spot weld cutter bit size for our trucks - 5/16, 3/8 - other?
Resistance is Futile
Re: spot weld bit size
Ive always used the 3/8's. Doesnt matter cuz your gonna miss the center anyway! Seems like I always have to pry something or drill it twice.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Airport Bum
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
#4 | |
1967custom Last edited by michael bustamante; 02-10-2009 at 12:05 PM. |
Hey Y'all!!
![]() This is what I have also. It works real well.
Just hopin' I live long enough to finish something!!! |
TexasBowhunter
I used a 1/4" bit.
Didnt miss too many times.
Build in progress for son's first truck. |
Here is a 3/8th" for $3.99
http://www.harborfreight.com/cpi/cta...emnumber=95343
#8 | |
Hey Y'all!!
#9 | |
I have use these cheap ones, they work quite well, as stated previously, just let it cut and don't force it.....it is 2 sided so you can flip the cutter over if it gets dull....well worth $4 IMHO ![]()
Hey Y'all!!
@ $35 iirc
![]() Shoulda went to Harbor Freight first...although, in my defense, I had searched aound the web and everyone had good things to say about the Blair cutters. Other brands were not very highly spoken of. I still would've tried the HF ones but didn't know they were so inexpensive.
Just hopin' I live long enough to finish something!!! Last edited by TimE; 02-10-2009 at 06:50 PM. Reason: added info |
thanks for the responses - big help
I have always ground my own out old drill bits.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
#13 | |
![]() I've heard good things about the Rotobroach, i believe it is the one that will cut nice round holes in sheet metal also, unlike drill bits and holesaws i just picked up one from harbor freight, cost me $4.99 instead of the internet price of $3.99 ![]() although it is nice to have a Harbor Freight in the neighborhood i'll try it out tomorrow ![]() can you elaborate?
![]() ![]() Last edited by joe231; 02-10-2009 at 09:15 PM. |
#14 |
Iv'e used the ones from Harbor Freight with success..BTW it does help to drill a 1/8 inch hole first, less wandering.
Bob |
#15 |
The old spot weld bits looked just like a forstner bit so I just took old drill bits and ground them to this shape and they worked great. When I wore one out I just re-ground. I am a cabinet maker/wood worker so drill bits where plentiful and grinding drill bits is a everyday task.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-10-2009 at 09:49 PM. |
#16 |
cool!
#17 | |
Hey Y'all!!
I actually bought them before I started using this site. Had them for a couple of years anticipating the eventual teardown of 2 or 3 vehicles. The '64 just happened to get bumped to first in line.
![]() Quote:
Let us know how well they work for you.
#18 | ||
Hey Y'all!!
Just hopin' I live long enough to finish something!!! Last edited by TimE; 02-10-2009 at 10:46 PM. Reason: added info |
#19 | |
Norman, OKC, and Tulsa will do! ![]()
#20 |
Hey Y'all!!
It must have been in Norman then. I was south of OKC, I do know that for a fact.
#21 |
![]() that's my 'hood!!!
#22 |
Wide Eyed User
I just did this to take out the tank mounts in the cab and just used a forstner bit. Worked perfectly... just no stop so ya gotta be careful..lol.. but I think I might check out the Harbor Freight version when I have to do it again...
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
#23 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Thanks for posting this ![]()
#24 |
Cap, When I ground the center point I would make it just long enough to center the bit. Also I would not make it an exact point leaving a bit of the drill bit. It just takes a bit of playing to get it right and as you well know some bits are better than others. The forstner bits are used for wood so they are ground to a point. Hope this helps. Good Luck
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-12-2009 at 01:01 PM. |
#25 | |
60-66 Nut
