Old 02-09-2009, 12:14 PM   #1
thefatguy
Saginaw 3-speed Transmission Capacity
Title kinda says it all. I repaired the rear oil seal in my 1969 GMC half-ton, and now I need to know how much to buy to fill it back up.
I imagine that I fill it up to the bottom of the fill hole, but how much is that? I can't find it in any of my books, and I'd rather not have a(nother) bottle of stuff sitting around collecting dust, nor do I want to make two or three trips because I didn't get enough.
Any help out there?
1978 Silverado Big 10 - "The River Runner"
1969 GMC C/10 - "The 2008-09 Winter Project"
thefatguy is offline   Reply With Quote
Old 02-09-2009, 12:55 PM   #2
Wrenchbender Ret
Re: Saginaw 3-speed Transmission Capacity
It will hold 3 pints when empty. Now would be a good time to pull the bottom plug & change it all. Yes you fill it to the level of the plug on the side.
Wrenchbender Ret is offline   Reply With Quote
Old 02-09-2009, 03:10 PM   #3
Green Machine
Green Machine's Avatar
Most (all ?) do not have a drain plug, remove the bottom tailshaft bolt, that will drain most of it out. Put some sealer on the bolt before you re-install it.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-09-2009, 05:20 PM   #4
thefatguy
Mine had a drain plug, so it was already drained. I got my three pints in, and only one half-full quart bottle left over. Man, that fill hole isn't easy to use. But, the way I figure it, I've now got another 150,000 miles before I worry about it again.
