Old 02-09-2009, 01:53 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Inline 6 guys, intake/exhaust gasket....POS!
What do you inline guys do for intake/exhaust gasket on your engines? I bought one from Clifford, and it worked for a time, but it like all the others I used, cracked then blew out. Does anyone make a copper/steel one?
I love these engines, but that is one area I think needed improved.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 02-09-2009, 02:38 PM   #2
Willy Prost
Re: Inline 6 guys, intake/exhaust gasket....POS!
Felpro model # MS9786
Willy Prost is offline   Reply With Quote
Old 02-09-2009, 02:44 PM   #3
blakeaz33
blakeaz33's Avatar
I bought a set from NAPA for my 250, believe it was their brand and have not had any issues with it. It was a steel gasket and I have a stock intake and exhaust on mine.
blakeaz33 is offline   Reply With Quote
Old 02-09-2009, 04:24 PM   #4
zeeklu
I always had gasket problems until i bought these bolts.http://store.summitracing.com/partde...1&autoview=sku Chris
zeeklu is offline   Reply With Quote
Old 02-09-2009, 06:46 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
When i used to run 6cyl's , I used OEM GM gaskets. If the intake is warped, you might have to double gasket it. If its really warped, you need it machined flat.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-09-2009, 08:10 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
I'd bet that is the problem. I kept having problems on the 292 in my '67 C-50 wrecker. I machined it (with the intake and exhaust manifold bolted together) and had no more problems.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-10-2009, 10:50 AM   #7
TP from Cntl PA
Well I got a Clifford intake and Clifford truck headers on it...........They were flat when I put them on(I checked). Seems like the ones I used cracked in the middle of the exhaust port, then blew out over time. Its annoying. Drive the truck daily and it runs like a swiss watch, and the only time I lay a wrench to it is for this idiotic gasket.
Hey Willy, is that Felpro steel?????
