Old 02-09-2009, 02:04 PM   #1
michael bustamante
michael bustamante's Avatar
throttle linkage question for you guys
If im correct the thottle linkage in our trucks is actual linkage all the way to 71 when it went to cable linkage, I know alot of people like to convert to this later cable type. How come? whats the difference? better responce or less chance of binding?
any help would be great thanks.
1967custom
michael bustamante is offline   Reply With Quote
Old 02-09-2009, 02:17 PM   #2
1970cstblazer
1970cstblazer's Avatar
Wink Re: throttle linkage question for you guys
The cable system is safer if a mount breaks. It is less likely to jam the throttle wide open if the engine shifts.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-09-2009, 03:50 PM   #3
michael bustamante
ok I can see that, any other reasons? Im asking beacuse I have access to a cable type gas pedal assy and am trying to decide if its worth it to convert, safety`s one good reason for. . .
1967custom
Old 02-09-2009, 04:42 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you are swapping to an odd ball motor, or an odd ball intake (some older ones the carb sat crooked) or a smaller high rise... the cable can be easier.
I prefer the rod myself.... at leasst, till a motor mount wears out... I've had one bind up a little, just enough to almost soil myself.
Old 02-09-2009, 05:28 PM   #5
68Stepbed
68Stepbed's Avatar
Here's how I did my linkage. These spherical ends swivel and rotate to aloow more play for engine mounts and what not. These are less likely to bind than standard linkage.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-09-2009, 06:35 PM   #6
michael bustamante
stepbed, mind if I ask where you got that throttle setup?
1967custom
Old 02-09-2009, 06:46 PM   #7
souljaboy9768
please I think we all want to know... Im needing a gas pedal to. I need the whole setup... anyone looking to sell me one???? PLEASE
souljaboy9768 is offline   Reply With Quote
Old 02-09-2009, 07:09 PM   #8
arkie726
arkie726's Avatar
Just a note about converting from rod to cable, the one I did isn't a direct bolt on, the rod type bolts on the outside of firewall, the cable bolts on the inside and setup differant, a bit of a bite!! And the pics of the SWEET linkage setup are GREAT!
arkie726 is offline   Reply With Quote
Old 02-09-2009, 07:14 PM   #9
69halfton
69halfton's Avatar
i have the linkage. ive had a motor mount break, and the throttle hang up a little, thank goddness being out in the country, i just waited it out until the motor wasn't torqing enough, and the throttle let go on its own. and it was a strait, flat road
i never new a chevy truck would go that quick!
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 02-10-2009, 09:19 AM   #10
68Stepbed
68Stepbed's Avatar
I ordered all my linkage parts from Lokar products. This setup wasn't all that cheap, but it works great. Hot rod shops, race shops and certain swap meet vendors sell parts very similar. I chose to go with the Lokar stuff because of the finish on the materials.
The throttle return spring setup also came from Lokar. They also sell throttle cable and pedal assemblies if your serious about changing to a cable. It's kinda $pricey$ though.
Matt
Old 02-10-2009, 12:21 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You guys need to get your FAQS straight. LOL
http://67-72chevytrucks.com/vboard/s...00#post1383300
The FAQ index by Krue.
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-10-2009, 04:59 PM   #12
Longhorn Man
you tried asking for one in the parts section?
Old 02-10-2009, 09:04 PM   #13
neonlarry
neonlarry's Avatar
One other reason to convert is that the cable pedal is free floating. You don't have to cut a hole in your new carpet for the base of the old style pedal.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-11-2009, 10:33 AM   #14
michael bustamante
this is true. And I do have new carpet and padding to install. . .
1967custom
Old 02-11-2009, 02:15 PM   #15
slednD1
slednD1's Avatar
to each his own,race cars do not use gas pedal cables,they use linkage.thier pedals also have a clevis type that allow you to use your foot to lift the pedal in the event of throttle bind that is usually due to not using a possitive throttle stop.cables can also frey and cable liners can melt and either of these could be disasterous.if you want my cable from my 72' it's yours.
slednD1 is offline   Reply With Quote
