Old 02-09-2009, 05:21 PM   #1
Longstep70
Junior Member
Welding frame - can i get some advice?
So I'm practicing welding frame material on a couple of stubs cut off from another frame i had lying around - around 1/8" thick i guess. I'm using my Miller 180 and .035 wire.
I started with the factory settings for speed and current on 1/8" steel - 4.5/50. I was trying to nail down my settings for full penetration. The first couple of tacks I tried i wasn't getting the weld all the way through. I started playing with the settings and the gap between the two pieces. Increasing both numbers helped but I was getting a *lot* of heat and a lot of material in the bead very quickly so i backed off the current and tried to bump the wire feed to try and increase penetration without building up a large bead on top. I got mixed results and I have a few pics. Can I get a little advice from the more experienced of the welders on here?
Here's my first couple of tacks showing the weld pieces and the gap I was trying:
http://i6.photobucket.com/albums/y23...e/IMG_3423.jpg
and here's the back of the same 2 tacks:
http://i6.photobucket.com/albums/y23...e/IMG_3424.jpg
Here is a later pair after tried running a couple of small beads. i know they don't look great but bear with me..
http://i6.photobucket.com/albums/y23...e/IMG_3427.jpg
and again from the back:
http://i6.photobucket.com/albums/y23...e/IMG_3428.jpg
By the end of this sequence I had nudged up the settings on the MIG to 5/60 and I still don't feel like I'm getting proper penetration even with a chamfer on the edges. How should I proceed here?
thanks
-Andy
Longstep70 is offline   Reply With Quote
Old 02-09-2009, 10:16 PM   #2
fixit-p
fixit-p's Avatar
Cool Re: Welding frame - can i get some advice?
Try decreasing your wire speed only When I weld uphill or over head I'll either turn my voltage up a bit or decrease the wire feed you can control the voltage somewhat while welding by increasing or decreasing you stick out also I would practice your welds going uphill for max penetration.
fixit-p is offline   Reply With Quote
Old 02-09-2009, 10:28 PM   #3
Twisted Minis
Twisted Minis's Avatar
I have a 175 for backup in the shop. For 1/8" plate I run it around 6 to 6.5 on the heat setting, and around 55 on the wire speed, and just go slow with the gun. Here's one from the 175.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 02-09-2009, 10:30 PM   #4
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Sometimes it’s better to cool it off and move slower, you have to give the material a chance to heat up. It’s hard to get tacks to penetrate without turning the heat way up.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 02-10-2009, 12:56 PM   #5
Custom 68
Custom 68's Avatar
Twisted, those are some nice looking welds. Is that a "Pushed" weld using an 80Argon 20 CO2 mix or what?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-10-2009, 01:00 PM   #6
Twisted Minis
The part on top of the frame rail is pulling, the part running along the side is pushing. It was all one stroke so I had to reposition. I was running 75/25 mix.
Old 02-10-2009, 01:52 PM   #7
Longstep70
Junior Member
Thanks Guys.
Twisted - those numbers are pretty much what i ended up with after playing around with my settings so I'm reassured. I need to practice though now I see your beads. =)
As for going slower to get heat into the material - I had NO problem doing that.
This seems like a pretty powerful little machine. I was trying to run the bead with a 1 -AND- 2 - AND - 3 type of rhythm from point to point to make sure I got a good deep weld at each point rather than running continuously along the bead - is that correct?
Thanks again
-Andy
Old 02-10-2009, 02:11 PM   #8
Twisted Minis
Ya it is a pretty good machine. Mine is in for warranty work right now, something with the circuit board. But I have done 3/8" in a single pass with no issues in the past. That's it's limit though, and it hits its duty cycle pretty fast at that heat/thickness.
I'm not quite following the 1 - 2 - 3 thing. I use one of two patterns. The "C" walking the torch to one side, then coming back towards the weld, and walking the torch to the other side, then repeat. Hard to explain. The other technique I use, is circles. Usually only do this when I want a weld to look like dimes, and I am pulling it. So the technique depends on the position for me too.
Old 02-10-2009, 02:27 PM   #9
Longstep70
Junior Member
Ah ok, I get what you mean with the circles - are you chamfering the weld at this material thickness?
By the 1-2-3 thing I mean I was pausing very briefly at a point, then moving on and pausing again, then moving on - like a series of tacks chained together with a slight 'hold' at each tack then a small movement and on to the next one. Is that clearer?
-Andy
Old 02-10-2009, 08:44 PM   #10
shortbed70
shortbed70's Avatar
6/55 and use a c pattern and push your weld. Also I think your metal is around 3/16" Circles work too whatever is easier for you and you cant always use one or the other. So get good at both. I have found over head welding (SUCKS) works better with the c pattern and verticle down works with both on steel mig. I'm going to try to get some vieo of different methods soon.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-11-2009, 12:05 PM   #11
Longstep70
Junior Member
I went out last night and tried a few short runs with the settings you guys advised and I definitely got an improvement. I realized I had been laying the gun tip down too flat to the workpiece and so i straightened up and instantly got much better weld penetration. I didn't have time to really practice but I'm going to get back to it at the weekend.
Should i be chamfering material of this thickness? I've been clamping it with a gap about the thickness of the material but the quick beads I ran last night I didn't chamfer and it didn't seem to make much difference.
-Andy
