Old 02-09-2009, 06:20 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Need help fast before dark!
My passenger side door was scraping kinda bad so decided to play with it, like an idiot i didnt know what i was doing so unbloted 2 sets of 3 bolts one on top, one on bottom, now the door is shut and i cannot get it open...
Hurry before it gets dark i drive this tomroow morning!!!
Thanks!
John
1999 Toyota Tacoma 4x4
Old 02-09-2009, 06:35 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Need help fast before dark!
Did you remove the bolts from the hinges, or the strike plate??
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 02-09-2009, 06:37 PM   #3
oldblue1968chevy
I loosened the bolts adjusted the door a lil bit (thinkin hey its gonna be better now) now its way worse than i started cant open the door and now got mad at it (shoudve walked away) and bent/scraped up the fender!!!!
so i walked away asap before things got worse now im here at the puter tryin to figure out how to fix it...!
John
Old 02-09-2009, 06:43 PM   #4
eightbanger
454 MAKES IT ROAR
Sounds like it's droped and locked itself into the strike plate...what about taking the door panel of from inside the truck and reaching inside to releae the door latch, maybe worth a try.
Nigel.
No more pain.
Old 02-09-2009, 06:50 PM   #5
oldblue1968chevy
im not sure if were both talking about the same thing..i can open and close it about 2" MAYBE enough to reach it from the inside with a wrench im not gonna mess with it ima just have passgeners exit and enter from the driver side....
but i bent my fender tryin to open it..greatt least its the fender with the dents in it lol i mess with it tomrorow after schoool..
John
Old 02-09-2009, 06:58 PM   #6
eightbanger
454 MAKES IT ROAR
Sorry mate I thought it was shut completly and you could not open it...I understand what you mean now. If you have it open about 2" and it gets hung up on the fender then you have moved the hinges to far forward toward the front of the truck...get your weight behind that door and start pulling and tugging it in the direction of the rear of the truck away from the fender and that should give you the clearence you need to open her up all the way. Good luck with it hope you get it sorted.
Nigel.
No more pain.
Old 02-09-2009, 07:00 PM   #7
oldblue1968chevy
yikes...
might go try that
duno how much a 140lb kid can pull but here goes..brb
John
Old 02-09-2009, 07:06 PM   #8
69halfton
69halfton's Avatar
any luck?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 02-09-2009, 07:17 PM   #9
oldblue1968chevy
nope..i could losten 3 bolts from the inside...
dad suggested i find a body shop (need to find one anyways) and see if they can fix it for a few bucks...i lossend bols pulled on the door, still nothing...arrhhgg
John
Old 02-09-2009, 07:26 PM   #10
eightbanger
454 MAKES IT ROAR
Thats annoying, I wish I was there to help ya. "Tip" when first you decide to move hinges it's a good idea to mark a line around them first so you can see how far you have moved from original position and in case you need to just go back to were they started.
Nigel.
No more pain.
Old 02-09-2009, 07:34 PM   #11
69halfton
69halfton's Avatar
how destroyed is your fender/door?
how destroyed is the paint on said fender/door?
try prying it GENTLY as well as pulling to get it moving?
only if your not worried about bending/paint chipping?
- Jason
Favorite caption:
Old 02-09-2009, 07:39 PM   #12
oldblue1968chevy
well...the paints chipping off when i try to open it..its dented in a lil now thanks to me...
i'll try pryin it tomroro after school thanks
John
Old 02-09-2009, 08:00 PM   #13
El Jay
Gone to greener pastures
Okay, right up front, up not unsympathetic. I've tried more little fixes that end up being big fixes before I was through, than I can count. Trust me on that.
I'm assuming you're talking about the hinge bolts that attach to the cab, not the door; from your description.
My question is; if the driver side door is working, what's the immediate rush?
What I would do is calm down & just walk away for a few days.
Then on a nice peaceful weekend, get another pair of hands to help you. lift off the hood (it's only 4 bolts, & mark the hinges' location on the hood 1st), and then pull the outer fender.
Yeah, it's a tedious PITA, but it's not all that difficult.
Adjust your door and reinstall the fender and hood.
It'll be a learning experience and a confidence builder.
Good luck with whatever you decide to do. And there are a ton of people here that can give you needed advice.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 02-09-2009, 08:03 PM   #14
oldblue1968chevy
yup good advice
im sure i'll have ?'s soon enough
guess thats what i'll do,
and its the bolts goin from the hinge to the door btw thanks
John
Old 02-10-2009, 02:33 PM   #15
El Jay
I woke up in the middle of the night & realized this won't work. There's a cowl bolt that requires the door to be open to access it.
Will the door open enough that you can get a distributor wrench on the bolts?
I saw a knock off of this 1 for about $*.
104 $27.25
"Reach around obstructions to turn the distributor lock nut with this double-ended wrench. It fits 1/2 and 9/16" lock nuts. Use an adapter to join wrenches or attach the wrench to a 3/8" ratchet or extension. Replacement part: 104-73 Coupler."
Old 02-10-2009, 03:20 PM   #16
truckpoorpackrat
If you still need to get the door open try using a couple of plastic spatulas, the kind you use in the kitchen. Put them between the door and fender where it hits first, hold them flat to the door while opening the door. Kind of like using a body spoon to pry it apart but the plastic wont destroy the panels. Happens a lot when cars are hit in the front. Hope this makes sense.
truckpoorpackrat is offline   Reply With Quote
Old 02-10-2009, 03:22 PM   #17
El Jay
Great tip.I'll put that in the ol' memory banks, for sure!
Old 02-10-2009, 05:12 PM   #18
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have always been told that the striker plate should be removed when lining up the doors. after you get the door lined up, install the stirker, and adjust the striker as needed.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-10-2009, 07:32 PM   #19
oldblue1968chevy
wont do nothin till the weekend i'll keep yall posted
John
Old 02-10-2009, 07:55 PM   #20
El Jay
x 2
Old 02-12-2009, 11:15 AM   #21
oldblue1968chevy
HOW DO I GET MY DOOR OPEN ITS HUNG AND STILL NOT OPENING IM WORKIN ON IT TODAY.....
okay, well im layin out of school (we raised 17,000$ for a lil kid in our county that has a real bad disease,cant rember right now) but anywho we gota freeday at school and a 4 day weekend, so i laid out of school
about my door, its still not opening, ima fix it today, go junkyardin,get a fan shroad and maybe everythign i need to convert to 5 lug disk fronts,what exactly do i need to get, 71-72 front everything between upper to lower ball joints all the disc stuff..the master cyclynder, and something else i forgot i think, how much should i offer for it, and how much should i say, no im not gonna pay x amount for this stuff thanks! goin outside now
John
