Old 02-09-2009, 08:29 PM   #1
drewdude92
72 chevys 4 life
drewdude92's Avatar
Question GM two barrel carb rebuild
has anyone done it or is it even worth it? is it hard?
or does anyone have a rebuild section for a two barrel carb?
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 02-09-2009, 10:42 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: GM two barrel carb rebuild
I've rebuilt them in the past with the kit from the auto parts stores. It's really pretty simple to do. You just have to make sure that you don't loose the parts as you remove them and remember or keep a record of where you removed them from. These days a digital camera is a great tool for keeping track of levers, small springs, bellcranks, etc.
I've never see a step by step procedure here on this site but here's a gentlemen that sells one on ebay pretty cheap if you need one.
http://cgi.ebay.com/ebaymotors/HOW-T...22174003r27920
68gmsee is offline   Reply With Quote
Old 02-09-2009, 11:00 PM   #3
mr48chev
mr48chev's Avatar
I'll second the take a few photos before you take it apart thing.
I've rebuilt a lot of them and they usually take well to a rebuild.
Read and follow the instructions and make sure you do each step of the instructions.
You need the carb number to get the correct kit and they don't cost much. You should be able to pick up a kit for under 20.00.
I have used the spray carb cleaner to clean carbs when I redo them but it works a lot better if you soak one in a can of carb cleaner. I'm not sure what the gallon size bucket with basket in it costs now but it will do several carbs and can also be used to clean small parts on occasion. You just soak it for a couple of hours in a new can, longer in the older stuff and then rinse it off well after you take it out of the cleaner. Being careful of course to not loose any parts
It might be worth it to pay one of the local shops to clean the carb for you. If you are friends with a mechanic you can probably get him to clean the carb and rinse it off for five or ten bucks. That should be cheaper than buying a can of cleaner with the basket in it.
Old 02-09-2009, 11:12 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I rebuilt the carb for my '67 six banger and it worked out well. If I can do it anyone can...
LockDoc
Leon
Old 02-10-2009, 12:45 PM   #5
drewdude92
72 chevys 4 life
drewdude92's Avatar
perfect lol i hope it turns out alright todays the day!
Old 02-10-2009, 04:53 PM   #6
LockDoc
LockDoc's Avatar
Good luck. Let us know how it goes...
LockDoc
Leon
Old 02-10-2009, 08:19 PM   #7
drewdude92
72 chevys 4 life
drewdude92's Avatar
well went to o reillys...they didnt have one in stock so they are shipping it to me tomorrow =)
Old 02-14-2009, 01:46 AM   #8
drewdude92
72 chevys 4 life
drewdude92's Avatar
well i got the carb to what i think is officially rebuilt...but saying how it was my first time ever....well find out tomorrow when i put the carb back on the truck....ill be jumping for joy if it runs..=)
Old 02-14-2009, 11:02 AM   #9
68gmsee
Active Member
68gmsee's Avatar
You already have it done and you gonna leave us hanging? It's only 2 bolts, dude.
It will run fine...
