Old 02-09-2009, 08:51 PM   #1
HarrisonTX
'69 3/4 ton brake job
Hey guys, my '69 3/4 ton custom camper's brakes are shot!
I have heard that on the older 3/4 ton's the rear axles need to be pulled to do a brake job. Is this so?
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 02-09-2009, 08:56 PM   #2
john
member #16
john's Avatar
Re: '69 3/4 ton brake job
It depends on what diff you have. The Dana's have outboard drums which will come off. The Corp rears have inboard drums that require pulling the axles. The corp rears have a round ten bolt cover.
john is offline   Reply With Quote
Old 02-09-2009, 09:02 PM   #3
mr48chev
mr48chev's Avatar
When you pull the wheel look and see if there are a couple of screw heads between the studs. If so unscrew the screws and then take the drums off. If the drum appears to be fastened on from behind the flange that the wheel bolts to you will have to pull the axles first then pull the hub and drum as an assembly.
Old 02-09-2009, 11:00 PM   #4
HarrisonTX
I remember tryin to check the brakes when i first bought it, and there were flat blade screw heads. They were so insanly stuck, and the brakes worked, so i said screw it.
So seeing screw heads means no axle pull?
'69 custom/camper
'86 k5 blazer
'06 Duramax
