02-09-2009, 10:14 PM | #1 |
Possible to use front coil springs from a 71 on a 76?
both 1/2 ton 2wd's..
02-09-2009, 10:16 PM | #2 |
Re: Possible to use front coil springs from a 71 on a 76?
I am almost positive they will.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-10-2009, 10:39 AM | #3 |
FYI.. if anyone ever needs to know.
I got lucky and found out that '72- are shorter by about 2.75" and have a spring rate that's about 150lbs/inch less. So stock springs for a '72- would lower a '73+ about 2.75". But they're also about .75" smaller overall diameter with a pigtail end whereas the '73+ springs aren't. |
