Old 02-09-2009, 11:21 PM   #1
mole2000
mole2000's Avatar
BB LWP PS Setup Help - Pics/Advice Please.
After searching a while I just haven't been able to find any good pics of a BB with PS. I was asked today whether I needed a single or dual pulley and I really have no idea. How can I determine this? My crankshaft has 3 grooves with alt belt on the outside groove and also on the single groove water pump pulley, leaving the inside 2 grooves empty. Would that indicate I can use either a single or dual pulley on the PS pump? I used the March Perf bracket for PS. Unfortunately no pics of that yet...
Thanks!
mole2000 is offline   Reply With Quote
Old 02-10-2009, 12:09 AM   #2
bsgmcc20
Im afraid of purple hangers..
bsgmcc20's Avatar
Re: BB LWP PS Setup Help - Pics/Advice Please.
I have a factory orginal 1970 gmc BB 396 with power steering i will take some pics in the a.m and hopefully help you with your question. let me know what detail pics you might need?
bsgmcc20 is offline   Reply With Quote
Old 02-10-2009, 07:25 AM   #3
mole2000
mole2000's Avatar
Great. Thanks.
A pic showing the crank pulley belt arrangement would be helpful. I haven't seen that info.
Thanks again.
Old 02-10-2009, 11:12 AM   #4
Willys47
Willys47's Avatar
here are some pic I have.They are using the short water pump
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-10-2009, 01:04 PM   #5
breeh
Recovering 67-72 Addict
breeh's Avatar
mole2000, unless you are going to change the entire accessory setup on your engine, the above pictures will not help you. You need a setup for a long water pump. These are much easier to find than the short water pump setup. Look at trucks with BB from '73 and up.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-10-2009, 02:07 PM   #6
mrh33916
Project '67 454
mrh33916's Avatar
I'm running the complete pulley system from a '86 Suburban. Sorry I don't have any pictures with me.
mrh33916 is offline   Reply With Quote
Old 02-11-2009, 04:32 PM   #7
bsgmcc20
bsgmcc20's Avatar
I took a shot of the pully and the front bracket as well as the tank. Let me know if you need any specific shots?
the fan schroud was in the way for most the pics.
hope these help
Looking at the long neck water pump u have puts your belt on the outer most pully groove The short waterpump puts it back so the p/s is the outter grove.
Old 02-11-2009, 07:55 PM   #8
mole2000
mole2000's Avatar
Great Photos. Thanks for that. It is at least getting a litle clearer for me.
I was able to get some shots today of March Perf PS Bracket installed.
From what I am seeing, I need to run my PS belt to the outer groove on the crank pulley.
I am also installing the March Alt Bracket. I hope that it moves the alternator back so i can use the outer groove for PS... Or should the PS pulley line up with the second groove on crank pulley? The pulley should be here Friday so it will be sorted out for sure then...
Anybody see any potential problems with this? Am I mismatching components?
Thanks!
