Old 02-10-2009, 08:25 AM   #1
62 apache
62 apache's Avatar
Third member
I did a few searches on this forum trying to see how to gear my 62 a little taller for the freeway and wanted see if anyone could backup my info i gathered before i head to the wrecking yard on my hunt. The third member is interchangeable from 55- 62 truck only correct? And the only way i am going to find a factory unit with higher gears than my 4.11s is to try and look for a truck that came with automatic? Hopefully some one here can clarify this for me. I know there are other options as far as later model rearends i just would like to keep the truck stock as far as drivetrain goes ...........for now! Thanks for anyones help
62 apache is offline   Reply With Quote
Old 02-11-2009, 01:07 AM   #2
Captainfab
60-66 Nut
Re: Third member
The other option would be a set of aftermarket gears.....but they are rather spendy.
http://www.ringpinion.com/PartsList....b-Differential
I know you don't want to, but it would be cheaper to convert to a 12 bolt.
Old 02-11-2009, 10:36 PM   #3
hewlett2002000
hewlett2002000's Avatar
Re: Third member
well i have a 62 rear end that came from a 62 with a glide that you can have. not sure about the difference in gears between the auto and standard trucks though.
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 02-13-2009, 01:28 AM   #4
rss396
rss396's Avatar
Re: Third member
I think the years are 55-64. A common gear for those years in two wheel drive is 3.90 gears. I picked up a third member at the local swap meet (Canby, OR) for $40.00. It was a 3.90 gear and works good.
1950 Chevy 1/2 ton 283 Mustang II
1961 SWB 2x4 235 six
2007 Silverado 1/2 ton Z71 4x4
1968 Camaro SS 396 / 502
rss396 is offline   Reply With Quote
Old 02-13-2009, 11:04 AM   #5
62 apache
62 apache's Avatar
Re: Third member
Thanks for all your help i am going to the wrecking yard soon. I found one wrecker that had a few third members not sure on the gears and he wanted $225 so i will explore my options and see what makes the most sense and is the easiest on the wallet.
