Old 02-10-2009, 08:50 AM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
LT1 Q's
OK, so the LT1 is built and sitting in my chassis now. My question is, can I block off the two coolant ports on the rear of the cylinder heads or is this vital? The line ran to the throttle body from the rear of the heads. Thanks
--Josh
Old 02-10-2009, 09:01 AM   #2
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Re: LT1 Q's
I blocked mine off on the '68 I built years ago.
FuelCellGuy is offline   Reply With Quote
Old 02-10-2009, 09:17 AM   #3
STOCKISH
STOCKISH's Avatar
Re: LT1 Q's
Thanks brother. Also, does anyone know if the 73 and newer mounts and engine stands will bolt to my 72 frame. I think those mounts look alot stronger and would keep engine in place even if the rubber failed.
--Josh
Old 02-10-2009, 10:44 AM   #4
Elephanthead
Re: LT1 Q's
The only purpose of that coolant is to keep the throttle body from freezing, so unless you live in -20F land, no reason for it.
Elephanthead is offline   Reply With Quote
Old 02-10-2009, 03:38 PM   #5
ulakovic22
Re: LT1 Q's
Yes, but that is not the only purpose for those lines. The coolant crossover is supposed to allow air pockets that form in the heads a place to escape so they don't cause hot spots. You can obviously block them off if you want, but why, they are only helping. If you keep them you can also just run the tube straight to the radiator, it doesn't have to go to the TB. If you don't have the crossover tube you can get the seals and make your own for cheap. A lot of people use braided line so it's flexible and makes it easier to remove the head(s) without crimping or bending like the hardline will.
ulakovic22 is offline   Reply With Quote
Old 02-10-2009, 04:16 PM   #6
nightmare
nightmare's Avatar
Re: LT1 Q's
Yes, the '73+ mounts will bolt to it, but since they stand about an inch taller on the top of the frame rail, I had to use 1" bar stock to "raise" the frame at that point.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
