Old 02-10-2009, 11:09 AM   #1
rex01atv
How many man hours for kp notch for 72?
How many hours for a skilled fabricator to install kp compoents bridge notch?
rex01atv is offline   Reply With Quote
Old 02-10-2009, 11:39 AM   #2
Thorbecke Bros.
Re: How many man hours for kp notch for 72?
i just put a step notch in and id have to say it took me about 4-5 hours. but im extremely picky and have to make sure that everything is square, level, and straight. i quadripple check everything.
Thorbecke Bros. is offline   Reply With Quote
Old 02-10-2009, 12:31 PM   #3
chevyrestoguy
chevyrestoguy's Avatar
That's a good looking truck!
chevyrestoguy is offline   Reply With Quote
Old 02-10-2009, 07:22 PM   #4
texastrendz
man i am installing one right now, it takes longer to remove all the damn crossmembers in your way then anything. i even have a plasma and it is taken a while. it really depends on if you want it smooth or not also. you have to trim the top cap and lower bottom plate to get a smooth look. from start to finish i will have about 10 hours in mine. thats with the bag brackets mounted and shocks.
texastrendz is offline   Reply With Quote
Old 02-10-2009, 09:14 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Look here: 8 HOUR NOTCH INSTALL
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-11-2009, 06:54 PM   #6
rex01atv
Thanks for all your feedback, My truck is already notched so I think it might go a litlle easier?
Old 02-11-2009, 09:27 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Probably not. It will likely make it more complicated, depending on how your current notch is installed...
-Chris
Old 02-12-2009, 05:55 PM   #8
Kontrol Phreaks
Kontrol Phreaks's Avatar
Let us know what you come up with time frame and some tips for anyone looking to do it in the future. I know I've personally installed tons of notchs so it's a simple procedure for me to perform based on experience. I would say that 5-6 hours for an average individual would be realistic.
Keep up informed.
Thanks.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
